@ridetilldawn avatar
MP3 500
MP3 500
New Gilera owner here in need of your knowledge & experience.
It appears that the service manual makes a rather large deal out of changing the drive belt on my 2008 Gilera Fuoco. I am new to the MP3 500/CVT scene, but consider myself mechanically inclined. Special tools include the variator locking tool, which I will need to purchase. Are there more special tools required for this repair?
Can I bust the clutch nut loose by using the E-brake to lock out the wheel? Does anyone have a pearl of wisdom on this repair that they would care to share?
Ok, that's enough stupid questions for now. Please feel free to chime in...
2015 MP3 500 ie Business
The E brake is not enough to bust the front or rear nut loose using standard tools.
Even though I have the special tools, I don't use them for this job. Instead I use a standard automotive impact gun BUT I do mark everything prior AND a torque wrench is required for tightening everything up to spec come assembly time.
MP3 500
MP3 500
Sbaert,
Any other pro tips for belt replacement? I will be using hand tools (1/2 & 3/8" drive) so I will try the wheel block with the 27mm, I guess. Are the videos for the MP3 400 belt replacement exactly the same as the Gilera? I'm having a heck of a time finding a good MP3 500 belt vid.
@madison_sully avatar
To break the clutch nut loose I apply the parking brake, and also squeeze the rear brake while turning the nut. Works fine.
MP3 500
MP3 500
Madison Sully,
Cool!
I just put new pads on the E brake, and adjusted it nice and tight thinking it might work. If the dealer was the last one on that nut , I will get it off. Just waiting for the belt from Scooterparts. A local Piaggio dealer here wanted $246.00 for that exact same belt.... Craaaaaazy.
Hey, what else should I know about this task?
the clutch nut is reverse thread, best to use an offset wrench and hold the 10mm shaft still.
old as dirt wrote:
the clutch nut is reverse thread.
Since when?
MP3 500
MP3 500
Old as dirt,
Yeah I did see that as an option. I was waiting for someone to chime in on that method. Thx! Anything else a newbie CVT guy should know about this replacement?
MP3 500
MP3 500
Jim C.,
I was also curious about that reverse thread that Oldasdirt had mentioned. Any videos specific to Gilera Fuoco that you know of?
MP3 500
MP3 500
Old as Dirt,
After viewing a few Gilera videos, that reverse thread on the clutch would a Negative, sir....
MP3 500
MP3 500
Here is a decent Gilera belt replacement vid. If you have a better one please post.
my mistake its the 10mm shaft reverse thread for torquing back to the nut.
MP3 500
MP3 500
Old as dirt,
No worries I think you were just checking to see if I knew what I was doing.
Laughing emoticon
[ Time: 0.0109s ][ Queries: 3 (0.0029s) ][ live ][ 313 ][ ThingOne ]
