@bluepotato avatar
2009 GTS 250
@bluepotato avatar
2009 GTS 250
Can somebody recommend to me a battery available on Amazon (USA) for my 2009 GTS 250?
I don't need anything fancy. I just don't want to end up ordering an incompatible battery. Crying or Very sad emoticon
Thank you for the help.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
I am guessing you did not wish to google & find the right battery for your Vespa or search the forum. But you are in luck here is a good battery for your Vespa
https://www.amazon.com/MotoBatt-MBTX12U-Lead_Acid_Battery/dp/B003YMRH70
@abner_bjorn avatar
@abner_bjorn avatar
@kz1000st avatar
@kz1000st avatar
https://www.batterysharks.com/Motobatt-MBTX12U-p/mbtx12u_m12-10-180-d.htm
I have had great luck with these people. The battery comes preloaded. My Nighthawk had one in it for four years before it crapped out.
@baba12 avatar
@baba12 avatar
Generally when it is shipped it is not preloaded.
When you buy a battery online you should make sure you have a battery tender /trickle charger to get it all filled and charged up.
A decent battery tender is this one https://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S?th=1
You may want one with a higher amp than the 750mA.
@bluepotato avatar
2009 GTS 250
@bluepotato avatar
2009 GTS 250
Thank you for the replies and recommendations!
@syd avatar
GTS300 Super (Heinz) GTS250 Super (Bulger)
@syd avatar
Did you check Autozone/OReilly/NAPA?
2023 Genuine Buddy 125
Or BatteriesPlus. They can look it up, and you can get the core charge back on the spot for the old battery. Their battery come ready to go and they have a great warranty should something go wrong.
@crazycarl avatar
@crazycarl avatar
Whichever way you go, find one that is AGM construction. Absorbed Glass Matt will hold a charge better and longer and is also more resistant to impact shocks - so it won't get damaged as easily as traditional wet cell types.
Motobatt is a very good AGM.
[ Time: 0.0112s ][ Queries: 3 (0.0049s) ][ live ][ 313 ][ ThingOne ]
