@jimvanmorrissey avatar
Vespa PX200
Vespa PX200
Hi folks -- quick one here about fuel lines. Book says 7mm x 14mm. I
can only find 8mm x 14mm hereabouts. Will that work? Seems pretty finicky to fuss over the difference but I've been stung by mucking around with fluid dynamics -- something I do not understand -- many times before.
FWIW I have an SI carb with the float chamber hole drilled out. And a SIP faster flow 2.0 tap.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
I use 5/16" (7.9375mm). Seems to deliver plenty of fuel with BGM fast flow taps. I think you'll be fine with 8mm.
Vespa PX200
Vespa PX200
Thanks SoCalGuy -- got the 8mm hose. Fits fine.
Cheers!
@jocco avatar
@jocco avatar
Its impossible to find a 7mm inner diameter fuel hose. At least for me.
The 8mm is too loose and might leak, I use the 6mm.
[ Time: 0.0081s ][ Queries: 4 (0.0017s) ][ live ][ 313 ][ ThingOne ]
