@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Just done the steering bearings and have tried to reverse bleed the system. but to no avail.
Now I have found a reservoir behind the plastics on right had side (looking at front)
Any ideas what this is for?? as I thought the reservoir wad above the tilt motor.
@pmatulew avatar
2009 MP3 400, 2004 Honda ST1300
@pmatulew avatar
If you're talking about up front. The bigger one is for engine coolant.
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Success bleeding Tilt Lock.
pmatulew thanks for the pic, yeah I knew what they are for the, I have circled in green, the reservoir is behind a hatch. in the plastics. Its filled with brake fluid, this was black so remove all and topped up fresh.
When I was reverse bleeding the tilt this other reservoir did not fill up,
I was definitely over thinking the tilt lock bleeding.
Succeeded by reverse bleeding them, tilting the bike left and right, then just activating the tilt lock button a few time to pressurize the system..
@pmatulew avatar
@pmatulew avatar
Not aware of any other fluid reservoirs.
Any chance of sending a pic of what you found?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
did fill the bearings with brakeflued???
piaggio mp3 500
piaggio mp3 500
I did the bearings last weekend. I tinkered a bolt with a grease nippel.
Pitty enough the right side has a dead spot in the centre. It is steering much better now.
I hope he didn't put brake fluid inside the bearings
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Sorry for late reply but here is poc of reservoir being plastocs
@pmatulew avatar
@pmatulew avatar
Well that's certainly a brake fluid reservoir right out of the parts bin.
What model and year do you have?
Normally the reservoir would be mounted higher than the rest of the plumbing loop. So what hydraulic circuit would be below that? Rear brake?
Aprilia Mojito 125
Aprilia Mojito 125
Wow! A hidden treasure!
@pmatulew avatar
@pmatulew avatar
Is that perhaps for the floorboard mounted brake pedal?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
thats for the footbrake or ABS and its needs new flued
@pmatulew avatar
@pmatulew avatar
Must be this then
[ Time: 0.0154s ][ Queries: 4 (0.0069s) ][ live ][ 313 ][ ThingOne ]
