piaggio mp3 500
piaggio mp3 500
Hi Guy's
My name is Roel from the Netherlands and I have a question.
When I drive my MP3 500 from 2014 on the Highway with full throttle, my engine stutters sometimes. It is like it doesn't get enough fuel or air or it's a misfire.
I replaced the battery, air filter, sparkplugs, oil, oil filter and cooling fluid.
Does anyone have an idea what the problem can be?
Cheers,
Roel
2015 MP3 500 ie Business
Errr . . . you just might be hitting the rev limiter.
The MP3 500 has a top speed of around 145kph.
@pmatulew avatar
2009 MP3 400, 2004 Honda ST1300
@pmatulew avatar
Yes, watch the tachometer. I think the rev limiter on the 400 kicked in at 8000?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
speedlimit is 160 or 8250 RPM
the wrong belt (size) and roller weights could also be a problem
But if you do that often it wont last a year and then you need a engine rebuild
some advertisment
Is de dealer te duur kom bij Maksor in de schuur
somewhat like the old red barn of OAD Razz emoticon Razz emoticon Razz emoticon
piaggio mp3 500
piaggio mp3 500
Thx guys for your answer
It can be the rpm limit
When I call Maskor he doesn't pick up the phone or calls back
Working on my vario and belt soon!
just a FYI the old red barn is no more, I traded it in on a spot on the lake.
Fyi re. top speed, keep in mind that the speedo gauge reads about 10% positive.
So if you see 165, your actual speed is about 150
piaggio mp3 500
piaggio mp3 500
Thank you Niko for helping me with the vario. Added Dr Pully rolls and a new original Piaggio belt,
Now the speed is 155 at 7500 rpm without stuttering.
2019 MP3 500 Sport
2019 MP3 500 Sport
I am not sure how great it is for an engine to have the guts wrung out of it for very long highway spells? To me at least, the MP3 500 engine doesn't sound too happy at 90ish mph or 150ish kmh, speedometer inaccuracies included. How you get beyond that I wouldn't know, I think that's the max speed I have seen, and the bike wasn't happy, and if you hit a few highways bumps you won't, either...
I probably wouldn't use it to do the 350 miles from the Bay Area to Los Angeles on I5 (a boring, straight highway you can do 85mph on all day, but which is also hot as hell).
[ Time: 0.0092s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
