@shipscat avatar
vespa 125 vnb1t
@shipscat avatar
vespa 125 vnb1t
hello peeps not been here in ages found a youtube video with some "clearer"
info on the devils work that is the dellorto si the clip is in Italian but can be youtube auto translated ish
www.youtube.com/watch?v=-t1wiE637JM&t=366s
take care and stay safe
@ray8 avatar
@ray8 avatar
Re: si carburetor
The SI carb in a stock setup is a like a juggler juggling three tennis balls. Perfect performance, but kinda lame, right?
We throw in an exhaust it wasn't engineered for. Now the carb is juggling two tennis balls and a bowling pin.
We kit the engine, expecting the SI carb now to juggle a tennis ball, a bowling pin, and a chainsaw.
@ray8 avatar
@ray8 avatar
Was so looking forward to the SIP carb tutorial that recently came out.
Barely a mention of the SI!
Oh well..
Jet Eye Master
Jet Eye Master
I really hope SIP continue these tutorials. Great information, just not enough of it. 20 minutes on carbs could have been 2 hours and still not covered 10% of the subject.
SI carbs are way more complex than they seem. Probably more information about them on here than anywhere else......in the world. If only the search function worked better people could actually find it.
Re: si carburetor
Amen to that, spot on analogy.
VNB VSC VMA VSX - o9c vbc vmb
True true
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Jack, this thread would be a perfect place for you to contribute some "Jack Tips" on the use, care and treatment of SI carbs.
@kowalski avatar
2005 Stellalossi 177 Fe
@kowalski avatar
To say that loses something in the translation would be an understatement.
The discussion of throttle slides was reasonably clear though. Bottom line: he says if you have a big bore kit, you want a No. 7 slide (flat bottom) or a No. 1 slide (smallest cut-out on bottom).
Wish I could make sense out of his discussion of air tubes and mixer tubes.
@ray8 avatar
@ray8 avatar
Oh yeah, the slide ( the "guillotine"). Another ball to juggle.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I made sure Stella had a flat slide and blocked the oblong hole in the top next to the throat. I wanted to try and make sure as much of the air coming in had fuel and oil mixed with it.
@ray8 avatar
@ray8 avatar
It'd nice if there were a dictionary of the YouTube Italian translations.
I got Guillotine and Wasp, so far.
Each of these slides, atomizers, jets, etc were made for a particular bike's design, right?
@oopsclunkthud avatar
3:5
I think the next time I build a tuned largeframe engine, I'm going to use a Mikuini BN carb from a jetski.
Seems perfect as it's downdraft, and has a built in pump.
@charlieman22 avatar
Nedminder
Nedminder
That's a pretty slick idea.
I see they are called 40-43?
Is that MM??
That'd be a whole lotta carb.
@kowalski avatar
@kowalski avatar
The translations range from comical to confusing. His term for the cut-out on the bottom of a throttle slide is "scasso," which YouTube translates as "burglary." His term for the air correction tube is "freno aria," which YouTube translates as "air brake."
2007 Stella 225
2007 Stella 225
Is that MM??
A 34mm version
https://thejetskistore.com/index.php/mikuni-jet-ski-34mm-carb-13-5057.html
3:5
the 34-28 seems to be the smallest, and would be just about perfect. the Venturi is 28, so throttle response should still be good.
Only time i've seen one used on a vespa was in the '80s with an RZ350 cylinder. that bike moved!
@ray8 avatar
@ray8 avatar
Yeah, hilarious! A brief dictionary would help a lot, even if just for laughs.
Vespe e Motore's excellent YouTube videos (also in Italian) are much more physically descriptive, which helps a lot. Unfortunately, he hasn't yet made an SI tuning video.
@ray8 avatar
@ray8 avatar
How'd that go? I tried this a while back (blocked the oval hole on the filter, in order to essentially negate the slide's cut-out effect).
Didn't help at all. But at that time I didn't realize I was already rich in the middle third of the throttle range.
2007 Stella 225
2007 Stella 225
I can't say, I don't have anything to compare to, I did that about the same time I completely removed the air filter and put on one of Patrick's venturi's.
@kowalski avatar
@kowalski avatar
For whatever it's worth, I checked my throttle slide today. This is for a 2005 Stella with Spaco/SI 20-20 carb. Given that Stellas were tuned to meet US emissions requirements, I was expecting a slide with some kind of cut-out. I was very surprised to see the carb already had a No. 7 flat bottom slide. Since I am only the second owner, and since I know enough about the first owner to know there is no way he would have been futzing around with throttle slides, I have to infer this was original equipment.
[ Time: 0.0189s ][ Queries: 3 (0.0037s) ][ live ][ 313 ][ ThingOne ]
