Volunteers Needed to Beta-Test New Server
Post Reply    Forum -> Not-So-Modern 12Next
GTS250 GTS300 MP3 500
Tue Apr 20, 2021 2:32 pm quote
Cross-posting this here, because I know you guys like to break shit.
VNB VSC VBC VSX
Tue Apr 20, 2021 2:33 pm quote
That was not directed at Ned or Mike.
bodgemaster
63 GL, 76 Super (x 2), 74 Primavera (x 2), 06 Fly 150
Tue Apr 20, 2021 2:36 pm quote
Testing... 1...2...3
I gotta be meeee
I gotta be meee
Anything broken yet?
Tue Apr 20, 2021 2:38 pm quote
Not a single log message has appeared in my console. So, you're not trying hard enough.
Tue Apr 20, 2021 4:27 pm quote
I'll take a look. How hard should I try to break things?
(I might be a bit of a professional in this area)
Tue Apr 20, 2021 9:11 pm quote
Coverage is probably more important than determination. It's still a chumpchange AWS server that will max out if you push it, so DDoS is probably not necessary. What I'm really after are all the PHP exceptions that I haven't found yet.
Tue Apr 20, 2021 10:08 pm quote
Does it need to be welded or ported?
Tue Apr 20, 2021 10:47 pm quote
It is shiny, so one could easily make that mistake. However, I can tell you from personal experience that servers do not like anything that arcs or anything with abrasive grit.
74 50s x3 78 P200 x2 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Wed Apr 21, 2021 1:32 am quote
jess wrote:
.... I can tell you from personal experience that servers do not like anything that arcs or anything with abrasive grit.
Well, I guess that leaves me out then
2007 Stella 225
Wed Apr 21, 2021 3:41 am quote
Trying the new server, my web browser has always flagged NSM as a non secure site. Are you going to update that for the updated site?
Wed Apr 21, 2021 3:50 am quote
Or dry chemical fire extinguishers. They really, really hate those. We had electricians working in our data center many years ago who started a small fire, looked around and grabbed the first fire extinguisher they saw. The problem was that they were working with the doors open, so the closest one was *outside* the DC, meaning it was DryChem rather than CO2.
They put out the fire, and eventually destroyed about $10 million worth of high end Sun servers (E6k's, among other things) in the process.
Anyways...I won't do more than some basic mapping, scanning, and maybe a tiny bit of scanning for known vulnerabilities and fuzzing.
Wed Apr 21, 2021 6:09 am quote
Yes. I've done it successfully in a test environment to prove out the process (automated with Let's Encrypt, thank you EFF). Since the server domain name has to match the certificate exactly, and since the new server is going to change to the main modernvespa.com domain, I opted to do the final signing after the switchover. That will probably involve some brief downtime for the site, but only for a bit.
Wed Apr 21, 2021 6:12 am quote
Wed Apr 21, 2021 6:14 am quote
Oof. That's a bad day at the office.
Thanks, that'd be very helpful.
Wed Apr 21, 2021 8:01 am quote
LetsEncrypt on Linux is SUPER easy to get going, it just needs an A Record on a Public IP address that the server is running on/behind.
Since you already have that, you could set it up and test it now (use the test side to validate the config, because they heavily rate limit the prod certs and you'll get locked out for 24 hours). I use certbot on my servers and have a cron job that auto-renews everything every 30 days. It's like buttah!
Wed Apr 21, 2021 8:37 am quote
couple things...are images supposed to be larger now?
(Just checking...I actually like it )
And I'm seeing intermittent looooooong page load times, like this form took 12 seconds to load, all waiting on posting.php. Second sub-load of it took 112 ms, though.
Wed Apr 21, 2021 9:22 am quote
They shouldn't be laid out on the page any differently, as I haven't touched any HTML or CSS. And ultimately all the uploaded images get resized after upload, so unless Imagick is broken (or missing).... hmmm. I should probably check that.
That's definitely not expected. I'm consistently seeing 100ms load times on my end. The next time it happens, can you check the stats at the bottom of the page? I'd be curious to know what the page render time was. That will help pin down where the delay is happening.
Wed Apr 21, 2021 9:39 am quote
This was in fact the problem. ImageMagick was not installed on the new server (and obviously not there by default). Good catch! Thanks for pointing this out.
You bring up a valid point about size, too -- I could probably bump the pixel size that all images get shrunk to. It's currently at 800, we could probably enter the 21st century and go all the way to 1024!
Wed Apr 21, 2021 9:52 am quote
six second query
Wed Apr 21, 2021 9:59 am quote
Long searches unfortunately do not surprise me. The search function on this old forum is pathetic. We will almost certainly retire the entire software installation in favor for something modern, but the migration is going to be... challenging.
So for the short term, I'm focusing on getting the old software up on modern hardware.
Thanks again for all the help.
Wed Apr 21, 2021 10:11 am quote
You going to get redis going, or just live with a FULLTEXT index on the subject fields and body text? I'd think redis would be the easiest option to hammer-fit something in.
2007 Stella 225
Wed Apr 21, 2021 10:31 am quote
It's 3x + faster on my android tablet using chrome.
Wed Apr 21, 2021 12:33 pm quote
I might use redis for general cacheing of infrequently-changed data. I don't think the whole of 15 years of MV posts would fit in the amount of RAM we have in our current instance, though.
Years ago I had started a project using Sphinx as a search replacement. It showed promise, but I couldn't get it quite the way I wanted it and I think I had too many irons in the fire at the time, so ended up not finishing it.
The debate I'm having is how much effort to invest in the old phpBB2 forum software. It really is almost 20 years old now. I could probably continue to modify and extend it, but ultimately it's still built on technology mostly from the last century.
To that end, I recently spun up a Discourse install to try it out and see what it was like to administer. I like a lot of the features it brings, but the complexity level is high and the migration is going to be wholly custom. The jury is still out on that one.
Wed Apr 21, 2021 12:35 pm quote
Excellent, thanks!
Wed Apr 21, 2021 1:30 pm quote
Jess - is the limitation on being able to post pictures between text related to BB code or would that be possible without creating entire science project. BBC works - if not fancy - but that would be a significant upgrade for users. My $.02
Wed Apr 21, 2021 1:57 pm quote
Ooh...good point about memory requirements for redis. I used sphinx in one of my past rails projects and while it was kind of a pain to get going, once I had it, it was fast and rock solid. That was a multi-tenant rails app, which was the real problem with it.
it looks like there are phpbb to Discourse migration tools, and I'd be happy to see a switch to markdown personally. I've never built or configured a discourse server, though, so I can't comment on how much of a pain it is to maintain or admin.
Wed Apr 21, 2021 3:19 pm quote
There are, but for phpBB3. Which we are definitely not. The official advice is to upgrade from phpBB2 to phpBB3 and then migrate to Discourse, but we are so heavily customized that I'm pretty sure even the migration from phpBBJess to phpBB3 would be just as much work as writing a wholly custom migration straight to Discourse.
The complexity of Discourse is mostly one of (for me) unfamiliarity: it runs in a Docker container, it uses Postgres, it is written in RoR, and it comes with support out-of-the-box for a slew of modern features. It really does have everything we could ever ask for in a forum package, but that comes with baggage. I don't know Ruby at all, I am barely functional in Docker, and Postgres is wholly alien to me. Is that a dealbreaker? No. But I am weighing carefully the trade-off between Discourse and what is a comparatively simple LAMP install here on MV (though we use an external MySQL database and some other AWS infrastructure).
The ultimate goal is for the forum to outlive me. To do that, it might need to be less complex, not more.
Wed Apr 21, 2021 5:11 pm quote
Fascinating stuff, but you lost me long ago. Sounds more unnecessarily complicated than a dang four stroke scooter, but necessarily modern.
I just posted to say you nailed it on for me in your lovely closing. That's just how I feel about my Vespas.
Wed Apr 21, 2021 6:21 pm quote
That makes sense. I'm old-school with Rails and even older-school on Postgres, but my Docker-fu is pretty weak. In my spare time, I've been working on learning and building a proper CI-CD pipeline for Rails->Docker or Kubernetes with Github Actions, but I'm nobody's idea of a Site Reliability Engineer.
From an architectural perspective, containerized deployments are where the future is headed. Increasingly, anything that's not SaaS is being designed to use Kubernetes clusters as the scale-out mechanism and then just loosely coupling the subsystems from there. IBM is in the process of porting pretty much their entire Enterprise & Security software businesses that way, but using OpenShift since they own it via the Redhat acquisition.
Doing a little googling, it seems like Discourse has pretty well killed off most of the competition, other than other apps which are basically clones.
If I can help out on any of the backend pieces, let me know. Depending on how busy I am over the next few days, maybe I'll take a run at setting up a Discourse instance to see what all's involved.
Is the current backend database schema itself customized, or still vanilla phpBB2 on MySQL?
Wed Apr 21, 2021 9:00 pm quote
My day job is as a software engineer for a Very Large Corporation. Mostly device communication stuff. All this IT, web, and server stuff is just something I've picked up out of necessity for running MV. And I am a rank amateur at it, to be sure.
Discourse brings a lot to the table. It's a modern re-think of what forums should look like, and also highly customizable through themes and plugins. There are things I *don't* like about it, but there are far more things that I really *do* like.
Thanks! That said, don't invest too much time unless you're really curious. I managed to get it set up, it wasn't too bad. Most of the install is automated. It's just the migration that was a sticking point.
It bears a vague resemblance to phpBB2 I've denormalized some parts of it for performance, and simply done away with bits that didn't serve an immediate purpose. I think the real issue is the features that have been added on. Attachments are handled much differently than stock phpBB (and stored in S3, too). Come to think of it, stock phpBB2 didn't even support attachments -- it was a mod, and some bits of it are still in place here now. It's... not a mess, exactly. But definitely a one-off software install.
2007 Stella 225
Thu Apr 22, 2021 2:29 am quote
Shows secured for me this morning, but no images in android using chrome browser.
P Series / Li / LML / Motobi
Thu Apr 22, 2021 3:59 am quote
im on it now.... seems snappy enough
ill see if i can break anything
Thu Apr 22, 2021 4:54 am quote
Sigh.
This might be a dealbreaker for HTTPS and MV.
Thu Apr 22, 2021 7:35 am quote
Sigh.
It's working fine for me on Android, Chrome on Windows, and Chrome on Linux as of 10:35 CDT.
300CC Italian scooter (RIP), 750CC Russian Sidecar,1650CC Bavarian ADV Tourer.
Thu Apr 22, 2021 7:53 am quote
Sigh.
I'll say one thing man, you know your stuff.
FWIW images load in Chrome on iOS however the browser is running WebKit in the Apple walled garden.
Thu Apr 22, 2021 8:06 am quote
Thanks for the update. I have moved the entirety of our static content (*.modernvespa.net) to CloudFront with a new certificate. I don't have any Android devices, and Chrome on Mac isn't as strict, so had no way of knowing if it was working or not.
2007 Stella 225
Thu Apr 22, 2021 8:38 am quote
I'll try it again when I get home it'll be around 16:00.
Thu Apr 22, 2021 9:15 am quote
Thanks much!
Thu Apr 22, 2021 10:58 am quote
the hell is wrong with the world!
useful help coming from NSM to modernize modern vespa, FFS!
Thu Apr 22, 2021 1:19 pm quote
Got the LetsEncrypt going, too, I see.
  DoubleGood Vespa T-Shirts
[ Time: 0.2418s ][ Queries: 70 (0.1854s) ][ Debug on ][ Thing Two ]
