Hi guys,
Can anyone explain the small screw on the bottom of a p200 carb box (and probably on all of the carb boxes) that locks in place with a weird k-shaped tabbed washed? Pictured here: https://www.scooterhelp.com/tips/engine/oil.mixer.old.vespa.html
in the photo on right, upper portion. Without that screw, there's a hole that lets you see the shaft of the oil injector gear.
Asking because I snagged a disassembled carb box on scoot.net and spent 30 minutes trying to figure out what this little screw and weird washer were for before I realized they fit in that hole.
@swiss1939 avatar
@swiss1939 avatar
Sounds like the screw that holds the oil pump valve in place.
@safis avatar
@safis avatar
This. It centers the pump's main body in the correct place, so the passages will be where they're supposed to...
[ Time: 0.0103s ][ Queries: 3 (0.0043s) ][ live ][ 313 ][ ThingOne ]
