P150s
P150s
As you can see it's a coil model p150
What are the coloured wires from stator
Which goes to coil, lights' ect there is no green wire any help appreciated
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Interesting, what year is it? Those non standard spade connections could be a clue. Maybe it was rewired with non standard colors? If someone doesn't come along that recognizes it you may need to pull the flywheel and trace the wires back?
@gravelrash2004 avatar
P Series / Li / LML / Motobi
looking at that
i would make the educated guess that the
blue and black are the power off to the regulator, stick a voltmeter on AC and check for a voltage when you kick it over
its fairly straightforward to work out the other ones..... if the yellow measures a dead short to earth on a continuity test on your meter. then check the values using the green as your target and see what the values are across the remaining wires
110 +/- 10% is the halls effect sensor
500 +/- 10% is your generator coil
[ Time: 0.0093s ][ Queries: 4 (0.0034s) ][ live ][ 313 ][ ThingOne ]
