Vespa lx/pk
Vespa lx/pk
Hello from France.
Just show you my new project.
A Vespa Lx with a 2018 Piaggio Liberty iget 3v motor.
Like in asia but with the front Wheel ABS.
All the parts from a Liberty 125 iget 2018 ABS.
Main modification :
Have to mod the wiring
Change the transmission cover to fit the 10 inch wheel.
The fuel tank with the fuel pump, have to mod the Liberty' fuel pump or find a lx ie fuel pump and tank.
The ABS system from a Gts 125 , phonic wheel and caliper support.
An airbox from a Vespa lx ie , the Liberty airbox is too long.
And the speedo of the Liberty , integrate into a lx speedo with a Sip glass.
External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text External inline image provided by member with no explanatory text
@collinsd65 avatar
LX 50
@collinsd65 avatar
LX 50
Pretty much compatible:
They both should have the same ingine.
Vespa lx/pk
Vespa lx/pk
Yes for the engine, just the transmission case to change.
On the other hand, the frame is not at all the same.
@collinsd65 avatar
LX 50
@collinsd65 avatar
LX 50
Right. I meant partswise. The trans is different.
[ Time: 0.0134s ][ Queries: 3 (0.0041s) ][ live ][ 313 ][ ThingOne ]
