@psgnw avatar
Vespa PX125 Lusso - Honda CB400N - Yamaha SR400
@psgnw avatar
I have a 75cc polini mounted on my smallframe (PK 50 XL2). Been riding it for a season or two with the standard 16/15 carb. I have a 19/19 carb + manifold laying around. Is it worth the hassle to mount the 19/19 carb? What would be improved with a bigger carb? More torque, cooler engine or just more wasted fuel?
The scooter is fine for town and small road use, but it could do with more power when going up hill.
I have a standard unrestricted exhaust mounted.
https://www.sip-scootershop.com/en/product/racing-exhaust-sip-road-banana_24176000?cr=3a6304bb-cc81-4ed5-9f63-1ff45fe1abfa&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=24176000&gclid=CjwKCAjwg4-EBhBwEiwAzYAlshWi1ggPZNu17cV3fMf1OcNvM54WIlMDJMeCNaT8Qdfdz1Lv9G-cZhoCchUQAvD_BwE
Stick one of these on. They are very good I'm told. I'm sure the small frame gurus will chip in soon. I'd start with one of these and upset carb by few pts. Exhauts are everything for a bit more grunt. I think the 19mm carb is a must for the 135 kit so probably not worth it to you and all the headache of setting up. You know your existing carb is set up right and all you will do is increase main jet size. At end of day you have 75cc but I know these banana pipes are very popular for the torque. I had a genuine piaggio banana pipe on a pk years ago and it was a lot more peppy than standard.
@psgnw avatar
@psgnw avatar
Sure I could put a "performance pipe" on it, but the carb I already have I don't care about more speed (I have my PX with 177 on it for that). I just wonder if it's worth slapping the carb on it for more grunt.
@moto64 avatar
@moto64 avatar
The 90's came with 16's and didn't go they didn't up to 19's until the 125. It's all about the air flow volume and speed through the venturi and a larger cab probably won't meter the fuel properly with the smaller cc volume.
On big American V8's they run with multiple carbs or multi-barrel carbs because the smaller venturis metered better than one big venturi in a single carb.
A pipe will surely make a difference and some are better for low end and others are better for speed. Jetted right, the 16 will most likely be fine.
@psgnw avatar
@psgnw avatar
Thanks for the replies. There is so many opinions about this floating around. Some say that a 19.19 will wake up the polini, and some say it would run best with the 16.15 carb.
Have anybody any experience putting a 19 carb on a 75cc?
I have the carb, but it's not tempting to mount it and redo the jetting (which is so cumbersome on a smallframe) if there would be less benefits than trouble
On the sip website for the polini 75 it states this SIP-TIP: Adjusting main jet and a new spark plug is a must. Transmission recommended here is at least the PINASCO pinion or a 3.72 transmission. The engine is made even sportier by a 16/ 16 carburetter, original exhaust with wider manifold, SITO Banana or POLINI racing exhaust.
[ Time: 0.0192s ][ Queries: 3 (0.0072s) ][ live ][ 313 ][ ThingOne ]
