Vespa 125 g.t.r., Vespa P200E, Crescent Skoterett
I'm looking for at front suspension/spring upgrade for my GTR from 1974. What are the best options? I'm looking for better performance but nothing too expensive. I want to keep it as close to stock looking as possible. Any insights or experiences to share?
@l4nff avatar
1972 Vespa GTR, 1963 Lambretta LI 125, Royal Alloy GP125
@l4nff avatar
I'm interested in this post. My 72 GTR dives like crazy. I have a stiffer spring that standard and have tried a few different dampers. I'm currently using Forsa which is better than the Escort I was using. I see it as dreadful design and can not understand why it was ever made like it is to start with.
Anyone got any great simple mods to this problem?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Look here:
Fronk shock
@rowdyc avatar
@rowdyc avatar
These look stockish and reduces the diving a lot. I have the 60psi version and they work great. The price has gone up since my purchase. https://www.sip-scootershop.com/en/product/shock-absorber-sip-performance-front_78000FSM
Silver is out of stock but the black is available. https://www.sip-scootershop.com/en/product/shock-absorber-sip-performance-front_78000FBM
The silver 100psi is available but the higher the psi the quicker the rebound.
https://www.sip-scootershop.com/en/product/shock-absorber-sip-performance-front_78000FSL
There are many choices out there that are better then stock but these worked for me and still looks stockish.
Thanks for the tip. Did you change the spring as well or just the shock abosorber?
holy cow I'm glad I bought the SIP shock back before the price went up!
I changed the spring and shock at the same time. I have yet to test it out though... so there's that
@rowdyc avatar
@rowdyc avatar
Nope. I kept the old 50 year old spring. If you think you want a spring, get the SIP upgrade vs the Stoffi. The Stoffi is just too stiff but great for an Allstate that has no shock.
@oopsclunkthud avatar
3:5
just my opinion:
short of changing the fork for a PK/Zip, there is no way to separate the suspension from the braking forces. It's a limitation in the design of a trailing link with the shoes mounted to the link.
The stock spring rate is good for absorbing bumps when not braking, but bottoms out when you apply the brake. So, while riding you can think of it as having suspension OR brakes, but never both at the same time.
An upgraded spring will suck when riding down the road, but can resist the braking force. so, while riding you can think of this as having nothing OR suspension + brakes, "Oh a bump is coming, I should apply the brakes to get the spring into a position where it can do something about it..."
A metaphor for life...
@gickspeed avatar
@gickspeed avatar
just my opinion:
Very well said.
It always gets me back to saying "maybe this model is not for you." Once you wrap your head around the trailing link system and understand and respect what you are working with, then driving it is that much better.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Problem with the pre-P trailing link is there's virtually no preload to the front shock and thus no rebound dampening from the static position.
[ Time: 0.0145s ][ Queries: 3 (0.0080s) ][ live ][ 313 ][ ThingOne ]
