64' VMA1T 79' P200E
64' VMA1T 79' P200E
Hello!
I am looking for some advice on tuning and upgrading a 79' p200E. It currently is original, with the addition of a SITO + exhaust pipe and it run's great but I'd love to up the acceleration and the top speed. I possibly have a compression issue, because I've been having issues with my top speed being a bit limited. I've been looking around online and the price for a 26/26 and the low end massoli 210 kit isn't horrendous. Would that be an okay pairing? What sort of modifications would you recommend? Lastly, how in depth would this be? (for context, I'm pretty good at wrenching, but this would be my first actual engine upgrade by myself.)
Thanks in advance!!!!
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I hadn't worked on a two stroke motor and replacing my first top end wasn't bad, as long as you limit yourself to the task at hand, don't allow scope creep. I would change the top end first and keep the 24/24 if you have one. Also hopefully someone here will chime in that has a 210 kit and can help with a good baseline for jetting a 210 with your carburetor and pipe. Getting jetting dialed in is actually the hardest part. The rest can be bolt on as long as you limit yourself to that from the beginning and make changes as you get more comfortable with what you're doing.
64' VMA1T 79' P200E
64' VMA1T 79' P200E
Unfortunately I have one of the weird American 24/24 carbs that was originally jetted to 120/be4/109
It has been described to be as a
"later model P motor with the squared nozzle in the venturi, and airbox spacer."
and pretty much every scooter head has recommended replacing it
@keaton85 avatar
Stella 2T, P200, Rally 180 Euro
@keaton85 avatar
I would trash the Sito and get a sip road instead. Also like stated above, don't bother with the 26/26. As for upgrading, takes about 30-45mins to swap the cylinder. Extremely easy!
A little more work is tuning with the right jets. You can NOT leave the jets stocks.
2007 Stella 225
2007 Stella 225
I bet if you do some looking on here you can find a recipe for the following with jetting.
Malossi 210 Sport
24/24 Carburetor
Sip Road 2
@rowdyc avatar
@rowdyc avatar
I would change the carb first and go from there before throwing money at something else. That carb setup is more like gas coming out of a 20/20. Even with the old Sito pipe you will notice a increase in acceleration and the top speed. Open up the carb box inlet to match the carb and maybe drill out float bowl hole to max out the benefits of the real 24/24.
You can always make changes after you have the baseline of how the bike should run without the restrictions of the old carb and stock pipe.
2007 Stella 225
2007 Stella 225
If your going to get a new 24/24 carburetor, get that on and working first, small bites. Then when you switch to a 210 you'll know the carburetor setup is working properly and you'll just need jetting.
2007 Stella 225
2007 Stella 225
https://www.scootering.com/the-vespa-big-box-exhaust-test/
Take a look at this test also, the Sito+ isn't even graphed to 6500 while others are getting closer or past 7000 rpm.
O-tuning in case you haven't seen it.
https://www.scootering.com/scootering-classics-vespa-tuning-upgrades-mega-feature-part-8/
⚠️ Last edited by Christopher_55934 on UTC; edited 3 times
@swiss1939 avatar
@swiss1939 avatar
They need to update that test as its now 5 years old!
64' VMA1T 79' P200E
64' VMA1T 79' P200E
okay, you guys are the bomb. I'm gonna order or otherwise try and source a 24/24 with proper jetting and go from there! If I decide I need more oomph I'll take your advice and match a 24/24, 210 sport, SIP road. Thanks so much for taking the time to help out!
2007 Stella 225
2007 Stella 225
If you need more I would put a SIP 2.0 road on next, it will be a step towards what you want, and help get you setup for the 210.
I totally agree, the road 2.0 is the quickest cheapest bang for buck you can fit, IMO.
@modkuo avatar
'79 P200, '74 VBC Super, '77 P125 Project, 1978 Rally 200
@modkuo avatar
Road 2 and drill the air filter -- the heart shaped area, if it isn't already. some of the new filters come with that area already opened up. The easiest beginning mod with no consequences if jetted correctly.
Or check The Road XL, its only about 50 bucks more and is the next gen from the 2.0 and if you go to 210 you are also stoked.
There are other exhaust choices out there as well.
Good start, have fun!
Jet Eye Master
Jet Eye Master
With the euro carb and jetting it will go better. However, unlikely to satisfy. I would get an autolube 26/26E, which will be better suited to what may very well happen next.
@chandlerman avatar
Lucky
78 Days Since Last Explosion
Lucky
@chandlerman avatar
Phardie, the one thing you didn't tell us going into this is what your ability level is.
Are you comfortable splitting cases and opening up ports, or are you wondering how to do an exhaust swap?
And how much more performance are you looking for, and how much reduced reliability/increased maintenance are you willing to sign up for?
If you have the skills and don't mind using them a lot more than on a stock bike, then by all means get the 26/26, the 210, and a SIP Road, then bust out your dremel to open up the ports. It'll give you a lot of performance, but still be damn near as reliable as stock. If you don't introduce air leaks or mess up your jetting.
Also, if you're going to put on a new top end, make sure your get your squish and port timings right would you're at it.
Lastly, welcome to the NSM Dark Side! Share some pictures of your bike!
@rfman81 avatar
A couple oldies
@rfman81 avatar
A couple oldies
Can this be clarified some more or some kind of post or article about it? It has peak my curiousity as I hadn't heard about it. I know some P200's come with the jetting but I was not aware that the 24/24 carb was any different than "normal" 24/24 carb. This is a first seeing someone saying the carb was physically different so I am genuinely curious.
[ Time: 0.0124s ][ Queries: 3 (0.0061s) ][ live ][ 313 ][ ThingOne ]
