@duane1 avatar
2005 et4
@duane1 avatar
2005 et4
Trying to do my upgrade to a malossi variator\belt etc on my 2007 LX150, but the variator is stuck on.
I had it off 2 years ago, but this time it seems to be stuck tight at the bearing \shaft.
All bolts are out and I can wiggle it slightly lose all around, but that seems to be stick\jammed up.
Tried PB blaster on the bolt\bearing and tapping all around to try and free up. Nothing worked.
Ideas?
@attila avatar
@attila avatar
Heat the central pin with a hair dryer or special on heater (variator shaft)
Don't use a flame..!
[ Time: 0.0078s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
