@andyscooter avatar
Vespa gt200
@andyscooter avatar
Vespa gt200
Has anyone bought a bike lift that works on scooters that doesn't cost the earth
Been looking at the hudrilic platform ones but not sure if the base of the scooter is able to take the weight
Not got loads of room so a massive 100 quid bike ramp is out of the question
And as you lot know everything vespa thought I would ask again 😂😂
@kimpossible avatar
Tethys - 2012 GTS 300
@kimpossible avatar
DIY
Hi, I don't have a lift. And I actually haven't built this yet. But, I've had it bookmarked and one of these days I will.
Scooter stand
0:7 And counting
0:7 And counting
Re: DIY
Scooter stand
I like that design.
@madison_sully avatar
You can find these used every once in a while. I got mine for ~$100.
https://www.harborfreight.com/1000-lb-steel-motorcycle-lift-68892.html
2007 Vespa 250 GTS
2007 Vespa 250 GTS
I love my H F table, adjustable height and low enough for this old man to roll it up there, It does require 50 pumps to get it to max height.
@lebo avatar
@lebo avatar
My Harbor Freight meets my needs.
@andyscooter avatar
Vespa gt200
@andyscooter avatar
Vespa gt200
They are what I class as ramps
What I'm thinking of looks more like a oversized car jack
Main thing I would use it for is removing wheels for tyre changing
@attila avatar
@attila avatar
500 EUR minimum for a decent one, I put it on my shopping list for the end of 2021
Believe me, when you have one you will use it for many things and not just for the scooter ... it can also be an excellent height adjustable workbench.
ET2 50
ET2 50
Re: DIY
Scooter stand
With current lumber prices in the US that's what? About $5000?
@kimpossible avatar
@kimpossible avatar
Wood
It's been about a year, but I love this place for lumber. I've gotten furniture grade plywood from them a few times. It is better quality, free delivery (!), and lower prices than lumber from the big box stores.
https://harborsales.net/Products/Panels/Wood.aspx
@attila avatar
@attila avatar
Even with some differences in color and strength, fir woods are generally quite similar, hard and resistant, marked by deep veins. They are used for structures and furniture made to last over time. The price in Italy is 900-1300 EUR / m³.
Instead, the price of iron profiles varies from EUR 0.60 to EUR 0.70 per kilogram, but to build a metal structure you need to know how to weld and have a different experience than building a wooden structure, which in my opinion is easier to assemble. .
Many of you don't know it but I was (many years ago) deputy production director and chief designer in a large wood furniture and structures factory (here the link: https://www.facebook.com/DEVOTODESIGN/ )
@aiosi avatar
@aiosi avatar
Re: Wood
I didn't really have a reason to go to this website but I did.
Now can somebody tell me what "Scooter Board" is?
https://harborsales.net/Home/ProductList.aspx?ProductTypeId=55&FilterType=Scooter+Board+UV
@silver_streak avatar
I use this... also from Harbor Freight. Works great, but you have to use the straps to get a scooter to balance properly.
It's a bit dear at the regular price of $299, but I got mine on sale a few years ago for about $180. Much more compact than the massive HF platform lift.
@pinkscooter avatar
@pinkscooter avatar
I have one of these and they work great: https://www.amazon.com/Extreme-Max-5001-5044-Motorcycle-Scissor/dp/B0196PAZ1S/ref=sr_1_18?crid=1QHTMDSWUKKEH&dchild=1&keywords=scissor+jack&qid=1619905885&sprefix=scissor+%2Caps%2C181&sr=8-18
@attila avatar
@attila avatar
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
I have this one , Works on my gts300 and many other bikes in the past .
eBay item 284131888550
@attila avatar
@attila avatar
Is it with through screw raising?
@kimpossible avatar
@kimpossible avatar
Re: Wood
"Scooterboard is moisture resistant and is coated white 2 sides with a beautiful non-glare finish. Direct UV Digital Printing, screen printing and vinyl adheres without any surface preparation. Scooter Board UV weighs 1/3 less than high-density hardboards such as Duron. It's 3/16" core is perfect for real estate sign frames.
Scooter Board UV readily accepts vinyl, digital flatbed printing, and engraving as well as a variety of screening inks. Since each material has different characteristics and longevity we recommend testing to determine the best method for your application.
Plus the cute picture of the doggie!
@kimpossible avatar
@kimpossible avatar
How do you balance even a scooter on something like that. The picture of the huge bike, yikes! There must be a method though.
@rallygeek avatar
@rallygeek avatar
I use one of these combined with a front wheel chock like this and it works ok. You do need to lie on the floor sometimes and isn't as convenient as full lift.
https://www.ebay.co.uk/itm/MOTORCYCLE-MOTORBIKE-FRONT-WHEEL-CHOCK-STORAGE-VAN-TRANSPORT-PADDOCK-STAND-/113853053211?_trksid=p2349624.m46890.l49286
@pammieellen avatar
2020 GTS 300 HPE
@pammieellen avatar
2020 GTS 300 HPE
Attila -- With the cost of wood in Italy -- you may want to consider making a marble motorcycle repair stand:P
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Robot from Vespa motorsport uses one of these on most of his YouTube video's , That's why I brought one
@berto avatar
@berto avatar
I think he uses it to support the bike and prevent it from tipping over? In other words, this isn't meant to completely lift it in the air?
@vespasfw3 avatar
2006 Vespa GTS250ie, 2004 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
@vespasfw3 avatar
That's the lift I have. I got it on sale at Harbor Freight for $249 a couple years ago. I've never used it. I still crawl around on the ground to change the oil.
GT 2.4
GT 2.4
But if you build the structure out of steel or bricks, you don't have the problems with wolves blowing it down that you do if you make it out of wood or straw.
0:7 And counting
0:7 And counting
ROFL emoticon
@attila avatar
@attila avatar
It's true!
If you then consider that I have been a wood furniture designer (AutoCAD) for many years (retired), I have the right ingredients.
But I got lazy ...
@attila avatar
@attila avatar
You can always dig a hole in the ground near the scooter and lower yourself into it, if you cannot lift the Vespa you can lower you.
jess wrote:
ROFL emoticon
Glad to read that you have a sense of humor that knows how to grasp the nuances...
@touring300 avatar
@touring300 avatar
.....or if you have a swimming pool........
@attila avatar
@attila avatar
The principle is that...if it works why not?
@der_blechfahrer avatar
Or a curb
@dooglas avatar
@dooglas avatar
I like it! But be careful when you are changing oil.....
@fleece avatar
@fleece avatar
maybe not if you have a Vespa Elettrica!
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
See scooterwest new video on YouTube
[ Time: 0.0251s ][ Queries: 7 (0.0083s) ][ live ][ 313 ][ ThingOne ]
