@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
I have a 1963 GL with a freshly rebuilt P200 motor and sip road 3 exhaust in it. I'm having a hard time getting to run right.
First the symptoms...
It will start right up
The idle is choppy but it will continue to on the stand
Throttle response on the center stand is good.
When I ride the scooter, it accelerates well but it will buck and hesitate when I back off the throttle.
Once this starts, I can pull in the clutch lever but the scooter still wants to cut out and die, unless I go to past half throttle and basically rev the motor.
By the time I get the scooter back home, it won't stay running anymore..
What I've tried so far...
New spaco 24-24 carb, main stack 160-BE3-118, idle jet 55/160
Set the mixture screw 3 turns out, and 2 turns, etc, etc
Set the timing with a timing wheel and gun, scooter fires at 24 degrees before TDC
Spark plug looks black
Tried a different idle jet
Checked compression, it's only 90 psi
Ran w/o air filter
The scooter has a scored rotary pad, but I don't think that's the problem.
Running out of ideas, not sure what to try next.
Video to follow.
@rowdyc avatar
@rowdyc avatar
From my limited observation, 1st check is the choke cable at the carb. Is it all the way in or is it pulled out a little bit? To me, on the video it seems a lil out but I could be wrong.
It seems the choke arm is pulled out and s/b more toward the float bowl
⚠️ Last edited by rowdyc on UTC; edited 1 time
@swiss1939 avatar
@swiss1939 avatar
What's your plug look like?
The dying on idle after warm sounds like mine when I'm rich on idle and fouling plugs fast.i also have to slightly hold throttle at lights to keep it from dying when idle is very rich. But your other symptom of bucking when letting off throttle sounds like a lean idle. So check your plug after using on stand and it dies. Also try turning af screw in half a turn to see if it stops the dying at lights.
@charlieman22 avatar
Nedminder
Nedminder
I'm with them.
Sounds rich at bottom end to me.
Perhaps start by running the mixture screw in a bit - and see if it moves you in the right direction.
You could also run at low throttle for a few minutes and then pull the plug to see if it looks wet - I suspect it will.
@langolson avatar
Vespa 125 VMA, Vespa SS 180
@langolson avatar
You mention 90 psi compression. You might want to check that the head nuts are torqued and that you have a good seal at the head and cylinder base. This has caused me issues like you describe.
@greasy125 avatar
@greasy125 avatar
90 is low and I'm thinking air leak. Or something along those lines.
Also, bump that idle up. At three turns you're nearly into the main.
Double check all connections and make sure you're not sucking air.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Concur with rowdy & greasy ...
1. Check that choke is closed all the way.
2. Idle sounds too low. Twist it up a couple hundred rpm.
@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
I checked the choke cable it's okay, also replaced carb and carb box gaskets, and correctly torqued cylinder head. I want to spray around the cylinder while it's running to check for air leaks but the type of spark plug lead that I have arc all over the place with the cylinder shroud removed. I'm going to see if I can find an NGK spark plug lead today.
The scooter is running even worse today, jerky, idle speeds up then slows down, for no apparent reason.
Jet Eye Master
Jet Eye Master
There seems to be a bit of white smoke when revved. Before running too much check the gear oil level is still there. If the main seal has fell out it will be making a mess of the casing.
As said 90psi is way too low, if it has been measured with a 2 stroke pressure gauge. If its a 4 stroke pressure gauge its probably more than 90psi in reality.
@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
Jack. I think you may be onto something, the scooter took 5 ounces of gear oil, and I haven't noticed any oil on the garage floor.
@chandlerman avatar
Lucky
69 Days Since Last Explosion
Lucky
@chandlerman avatar
That motor sounds all kinds of off. Also, it sounds like like it's misfiring, not just idling poorly, so you could have electrical issues clouding the issue further.
@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
From what I understand, the top end sucks in the gear oil until there's basically none left, and from that point the motor is sucking air, and then it is air leak. I think that's what happened between yesterday and today.
I don't mind pulling out the motor, splitting the cases and installing new seals, I hope the clutch seal is intact and hasn't damaged the cases.
Jet Eye Master
Jet Eye Master
White smoke and missing oil are big clues. As it's just been rebuilt there are two possibilities, seal fell out ( less bad if full rubber ridged type) or too much gasket sealer, causing to oil sucker issue (fingers crossed it's that).
Be sure to pressure test it after.
@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
I pulled the motor and opened the cases to see what was up with the clutch side seal. The seal looked okay, not only that but when I drained the gear oil, before pulling the motor, to my surprise, nearly 12 ounces came out.
But I did spot a possible problem. The circlip holding the clutch side bearing in place was not seated all the way into the groove. Even when I tried to pop it in.
I know I'm grasping at straws here, but is it possible that actuating the clutch lever was moving that bearing? Causing problems?
In other news, I ordered a new piaggio 200 top end. And I'm planning to pressure test the motor before I install it this time.
@safis avatar
@safis avatar
That's definitely your problem. Crank moves a bit when clutch is pulled so having the circlip out of place probably moved the bearing along with the seal...
@vpfalcon avatar
86 T5, 71 Rally 180
@vpfalcon avatar
86 T5, 71 Rally 180
Back to work on the GL after a few weeks working on plumbing and garden stuff. I decided to install a new crank, it's a Jasil. I noticed when took a close look at the old crank that the flyside bearing race was installed flush onto the crank, instead of the recommended .5 mm. I'm not sure if that affected how the motor ran.
So I've got a new piaggio 200 top end, new crank, new clutch side bearing and seal. Going to torque the case bolts and work on installing the cylinder
[ Time: 0.0171s ][ Queries: 4 (0.0066s) ][ live ][ 313 ][ ThingOne ]
