Okay folks, server is going down. EDIT: We’re back!
GTS250 GTS300 MP3 500
Sun May 02, 2021 5:00 pm quote
Be back in a few hours, I hope.
Sun May 02, 2021 7:12 pm quote
So, the database upgrade did not go quite as planned. I had to roll back to the original and then make a few of the lesser mods that I had planned, but not the big MySQL version upgrade.
Anyway, we’re back.
LX190, Primavera
Sun May 02, 2021 7:17 pm quote
Yay!
Mon May 03, 2021 12:48 am quote
The best thing about this change is that Jess came back to us more often, I felt like someone whose closest relative had gone far and you saw him every now and then.
With gratitude
Attilio Ferrari aka Attila
Mon May 03, 2021 1:01 am quote
Jess .... does not make me edit the posts after entering them, I need it for grammar corrections otherwise I write bullshit.
VNB VSC VBC VSX
Mon May 03, 2021 5:51 am quote
Agreed. I noticed the same.
(The edit feature isn't functional... not that you write bullshit.)
2013 BV350
Mon May 03, 2021 6:32 am quote
Hi Jess!
I'm glad to discover that you are still with us and keeping busy. I've used this site and owned three scoots since discovering MV. Thanks to this site, I've learned so much to drive safely and maintain (yup, I wrench.) scoots. Thanks for everything.
Mark
Mr F.
Mon May 03, 2021 7:35 am quote
Mon May 03, 2021 8:11 am quote
Sorry, folks! I busted the Lambretta.
Trying to figure out what went wrong.
Mon May 03, 2021 9:07 am quote
Indeed it seems that the expression on your avatar's face has changed ...
Mon May 03, 2021 9:52 am quote
Well that was no fun.
I upgraded the database last night. Specifically, I changed all MyISAM tables (which are ancient and largely unsupported) to InnoDB. Which makes sense, right?
Except that InnoDB supports ROLLBACK, and so does the forum software. Unbeknownst to me, though, there was a SQL transaction that's been failing pretty much constantly because (drumroll...) I removed all the banners, and the banner stats code can't cope with updating empty stats. Which triggered a rollback on editing posts.
If you're not following this, don't worry. It's ridiculously complicated and also ridiculously absurd.
I think it's fixed now, but there's a strong chance there are more errant SQL queries that will trigger a ROLLBACK in the database. I am logging them now and will keep an eye on it.
Thanks again for your patience.
EDIT: Editing to add that I am editing this post. Heh.
GTS300 Super (Heinz) GTS250 Super (Bulger)
Mon May 03, 2021 10:26 am quote
Nice picture of Patrick. Good to see him pop up too.
Mon May 03, 2021 10:28 am quote
Here's the back story for that picture: MP4-500 Project
Mon May 03, 2021 11:09 am quote
Good one. I noticed the two-time Cannomball SYM in the background too. I'd bet Patrick could'a done it!
Mon May 03, 2021 11:54 am quote
wow its slower now than before
Mon May 03, 2021 1:43 pm quote
speed has picked up ALOT. thank you
Mon May 03, 2021 1:44 pm quote
Fingers crossed. I am not entirely sure this is going to continue to function.
LX190, Primavera
Mon May 03, 2021 2:41 pm quote
I was going to suggest deleting the MP3 forum might help tidy things up , but it does have that one redeeming post.
Mon May 03, 2021 2:54 pm quote
Which isn't even in the MP3 section. Errrm, this is awkward.
LX190, Primavera
Mon May 03, 2021 3:08 pm quote
Maybe consult MV-Bot for neutral advice?
Mon May 03, 2021 3:15 pm quote
MV-Bot is neutral in the same way that a hand grenade is neutral.
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Mon May 03, 2021 5:04 pm quote
Huh. Your post doesn't indicate that it was edited. I'd swear I saw that in the past.....
So here's me editing it to see if it says it was edited.. 3...2...1...
Nope, no indication it was edited. Commence chaos...
And, edit...
Mon May 03, 2021 5:07 pm quote
Um, so, who exactly "throws" MV-Bot then?
Mon May 03, 2021 5:18 pm quote
It only shows "edited" if it gets edited after someone replies to it. If it's the last reply in the topic, then the edited tag doesn't get applied.
Mon May 03, 2021 5:19 pm quote
It's a mystery. I mostly don't even know. I think the moderators change her password whenever they need her to post.
Mon May 03, 2021 5:30 pm quote
And, edit...
Crap, chaos averted.
Mon May 03, 2021 10:50 pm quote
My IT experience is limited to the knowledge and use of CAD / CAM programs for mechanics and woodworking for furnishings. Ask me to disassemble and reassemble an engine and I will do it but with a PC more likely I washed it down with gasoline to set it on fire.
Tue May 04, 2021 5:59 am quote
I am a professional software engineer, and if I'm honest there are days that I would do the same.
  DoubleGood Vespa T-Shirts
[ Time: 0.0376s ][ Queries: 25 (0.0199s) ][ Debug on ][ Thing Two ]
