Sprint / Primavera / Liberty 150 Rear Shock Preload
2021 Piaggio Liberty Sport 150
Mon May 03, 2021 10:02 am quote
Hi all,
I recently purchased a Liberty 150 and the rear shock preload was set to "1" out of "5". Is this softest setting the best to use? I am 185lbs and haven't bottomed out the scooter's suspension but it seems "3" would be where the bike would be set to by default. Any thoughts?
2016 LXV 150 ie, 1978 Vespa P125, 2019 Piaggio Liberty 150
Mon May 03, 2021 3:44 pm quote
I weigh between 120-125, add a few pounds for gear but my setting is #1, so if you were using 1 of my scooters I would go up to 2 or 3, and I run my front tire pressure at Just Below factory settings, on the Liberty thatís 29.5, but I tend to have 28.5-29# as my scooters hold the road better, with My weight and a very slight less tire pressure. For you on my bikes, I want that front tire at that factory setting for pressure. And as my scooter accident was absolutely caused by that front tire not only being too high a pressure for MY light weight and the road we were on, but actually over recommended pressure...and NO, I was not the 1 who had over pressured that tire.. owner did and forgot or just didnít think about that and what I weight and a steeply curving downhill ride...
So, yes to adjusting that back shock and Please do check tire pressure often.
  DoubleGood Vespa T-Shirts
[ Time: 0.0373s ][ Queries: 26 (0.0200s) ][ Debug on ][ Thing Two ]
