Fri May 07, 2021 7:03 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 7:03 am linkquote
Has anyone installed this on their MP3? TIA
https://www.amazon.com/gp/product/B00MEQ25X8/ref=ox_sc_saved_title_8?smid=A4TFIYKVYQ2ST&th=1
Fri May 07, 2021 7:09 am
2015 MP3 500 ie Business
Fri May 07, 2021 7:09 am linkquote
That is VERY expensive for a 3rd brake light. Besides, it sort of defeats the purpose of a 3rd high mounted brake light due to the relatively low location of the license plate.
I use the SHAD 3rd brake light, and installed perfectly in the light of sight of drivers following me onto the original Piaggio luggage rack for the top case since SHAD is the supplier to Piaggio.
I bought the SHAD light on Amazon.
Fri May 07, 2021 7:13 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 7:13 am linkquote
Thanks! My new-to-me MP3 has the top case and rack, so this looks like a better option.
Fri May 07, 2021 7:21 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 7:21 am linkquote
Do you happen to know what the part number for that is? I can't seem to find one like it online.
Fri May 07, 2021 8:44 am
Fri May 07, 2021 8:44 am linkquote
2 different extra brake lights,
the Volo uses a sensor when your slowing down to activate with out touching a brake lever.
the shad light is tied into your existing brake wiring to activate when applying your brakes.
Fri May 07, 2021 9:02 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 9:02 am linkquote
Got it. Thanks, OAD. The sensor type was what I was looking for. Thanks for the clarification.
Fri May 07, 2021 9:35 am
Fri May 07, 2021 9:35 am linkquote
Sensor or not, but a light that sits that low to the ground is not going to pull someone's attention as much as a bright light that hits them dead in the eye.
Anyway, here is a eBay link to a SHAD light.
https://www.ebay.com/itm/174130422839?hash=item288afb6437:g:x3kAAOSwxkpd-z2Z
Fri May 07, 2021 9:36 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 9:36 am linkquote
Thank you!
Fri May 07, 2021 10:16 am
Fri May 07, 2021 10:16 am linkquote
you can mount it higher up, it DOESN't HAVE to go at the license plate.
mount it on the bottom portion of the top case and put a Vanity plate in it, great for swapping top case between multiple rides.
Fri May 07, 2021 11:00 am
MP3 400 "Orion"
MP3 400 "Orion"
Fri May 07, 2021 11:00 am linkquote
Oh, that's an idea! How would you go about mounting it, if you don't mind my asking? I wouldn't want to drill holes in the top case.
Fri May 07, 2021 2:41 pm
Fri May 07, 2021 2:41 pm linkquote
pics of your top case?
Sat May 08, 2021 9:37 am
MP3 400 "Orion"
MP3 400 "Orion"
Sat May 08, 2021 9:37 am linkquote
Hereís a pic.
Sat May 08, 2021 12:19 pm
Sat May 08, 2021 12:19 pm linkquote
I don't see where you possibly mount that thing without interfering with the handle/lock.
And if you did, you would probably have to leave the top case attached permanently.
One more thing, the pic shows a older gen MP3. Don't know if SHAD was the OE supplier to Piaggio for those earlier gens. I am more familiar with the 3rd gen (current) MP3 variant (see pic below).
Sat May 08, 2021 12:28 pm
MP3 400 "Orion"
MP3 400 "Orion"
Sat May 08, 2021 12:28 pm linkquote
Yeah, this one's an '08.
Sat May 08, 2021 1:22 pm
Sat May 08, 2021 1:22 pm linkquote
install a top case top rack and mount to that.
Sat May 08, 2021 3:26 pm
2010 MP3 250 (sold), CTX700D
Sat May 08, 2021 3:26 pm linkquote
The Lovely Wife (tm) had the vololight on her mp3 and it currently resides on her BV350. I think it is okay. Not great, but okay. She has lighting on her top case that helps. I don't remember where the power comes from for the vololight, but it wasn't difficult.
I have this on the back of my Honda.
https://admorelighting.com/product/admore-smt-light-bar-small/
Its a bit more money and ties into the brake/signal wiring. I think it is more noticeable. I have it mounted to the underside of the top case base. It was the first and only thing I've wired to the Honda, thus, I broke some clips making it happen.
Kilo
Sun May 09, 2021 11:16 pm
Sun May 09, 2021 11:16 pm linkquote
$134 for a 3rd brake light (Admore)??? Is this a joke???
You guys must be smoking something you probably shouldn't be.
The SHAD light is available for $100 less, does the same thing, and integrates perfectly with the factory rack mount.
I'd rather spend the $100 on a replacement Piaggio drive belt.
Mon May 10, 2021 6:08 am
Mon May 10, 2021 6:08 am linkquote
To each his own, my friend. I want God and Country to know I'm stopping.
And, to be clear, the shad light doesn't have programmable flashing or turning indicator.
Mon May 10, 2021 2:22 pm
Mon May 10, 2021 2:22 pm linkquote
exactly, 2 totally different light applications and functionality.
Tue May 18, 2021 4:36 pm
2K9 MP3 500
2K9 MP3 500
Tue May 18, 2021 4:36 pm linkquote
Anyone know whether the SHAD light will fit into my GIVI rear bag?
It looks like a universal brake light that can mount into my GIVI as well.
Tue May 18, 2021 7:50 pm
Tue May 18, 2021 7:50 pm linkquote
No a shad fitted light will not work in a Givi top case like the one in the pics you posted.
Wed May 19, 2021 1:22 am
2019 MP3 500 HPE Business
Wed May 19, 2021 3:28 am
Wed May 19, 2021 3:28 am linkquote
my post is not false a SHAD kit light WILL NOT bolt into a GIVI top case.
there is a GIVI kit light available for a GIVI top case but that is not what the poster was asking.
Wed May 19, 2021 3:50 am
Wed May 19, 2021 3:50 am linkquote
it's a misunderstanding sorry
Wed May 19, 2021 8:27 am
Wed May 19, 2021 8:27 am linkquote
But the SHAD light will mount with little to no modification underneath the shelf of the luggage rack regardless of brand as it is a pretty universal device.
See my earlier pic in this post
Thu May 20, 2021 3:50 am
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Thu May 20, 2021 3:50 am linkquote
Givi and shad are the same company :+ years ago givi or shad did take over the other the italians say that they did take over shad and shad did say the opposit
Thu May 20, 2021 4:23 am
Thu May 20, 2021 4:23 am linkquote
Every one of my rides starts in the dark. Every one. So I really like my admore led brake light. ...mounted under the OEM topcase on.my Liberty150i. Even in the 'resting' (DRL) mode....it is very noticeable and well up in the driver's vision. Worth every penny.
  DoubleGood Vespa Scarves
[ Time: 0.0462s ][ Queries: 26 (0.0227s) ][ Debug on ][ 156 ][ Thing Two ]
