Wed May 19, 2021 8:16 am
Piaggio mp3 500
Piaggio mp3 500
Wed May 19, 2021 8:16 am linkquote
Hi, problem with the engine management, I changed the tyre the other week and now the bike will start, but it chuggs and starts and stops when I try to pull away, it doesn't stall, just loses power, the asr is on and the abs is flashing, but I can't give it any throttle to do a re calibration on the back wheel, anyone any suggestions, thanks stevie
Wed May 19, 2021 8:29 am
2015 MP3 500 ie Business
Wed May 19, 2021 8:29 am linkquote
Model year of the MP3???
Current gen (2014 and newer) with ASR/ABS needs to have the ASR recalibrated every time a new rear tire is fitted.
Wed May 19, 2021 8:30 am
Piaggio mp3 500
Piaggio mp3 500
Wed May 19, 2021 8:30 am linkquote
It's a 2015, but I can't recalibrate it as it loses power when I throttle it, it chuggs,
Wed May 19, 2021 11:25 am
Wed May 19, 2021 11:25 am linkquote
Check for vacuum leaks, and also make sure the clamps on the snorkel hose between the airbox & throttle body is tight and not showing any signs of sucking in false air.
Easiest way to check for air leaks is to use carb cleaner on suspect areas, if idle changes you've found a leak.
Wed May 19, 2021 12:01 pm
Piaggio mp3 500
Piaggio mp3 500
Wed May 19, 2021 12:01 pm linkquote
Thanks for your reply, but I'm convinced it's something to do with rear wheel, everything was perfect until I changed it over,
Wed May 19, 2021 12:14 pm
Wed May 19, 2021 12:14 pm linkquote
Could be you didn't install the rear ABS sensor properly. Not installed properly, it will give the ABS and ASR systems major grief as the ASR cuts back engine output.
Thu May 20, 2021 9:54 am
Piaggio mp3 500
Piaggio mp3 500
Thu May 20, 2021 9:54 am linkquote
Yeah I've done something wrong, the mechanic is collecting it tomorrow before I take a hammer to it, thanks for your help,
  DoubleGood Vespa Scarves
[ Time: 0.0381s ][ Queries: 22 (0.0195s) ][ Debug on ][ 156 ][ Thing Two ]
