Fri May 21, 2021 6:37 am
Vespa ET2, MP3 250ie
Fri May 21, 2021 6:37 am linkquote
Hey all. It looks like itís time to replace my shocks. Any advice on what to get? Iím 5 10, around 170lbs ride with a passenger frequently who weighs anywhere from 110 - 200.
Was told stock are around $300 for a set but would be willing to spend a little more if thereís a good reason.
Thanks in advance for the helpful suggestions![/quote]
Fri May 21, 2021 6:49 am
2015 MP3 500 ie Business
Fri May 21, 2021 6:49 am linkquote
Get a set of Bitubos. They are the single best improvement you can do to a MP3. Shame on Piaggio for selling such a expensive bike with a suspension that is about as comfortable as a brick wrapped in a bit of rubber.
Fri May 21, 2021 7:26 am
Fri May 21, 2021 7:26 am linkquote
How do I know which size to get? I know the 2008 mp3 250 has 12 inch wheels. Does it use the same shocks as other Piaggio scooters? Finding a lot for the 400 and 500 but not the 250
Fri May 21, 2021 9:05 am
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Fri May 21, 2021 9:05 am linkquote
41.5cm and the 400 500 wil fit also the 250 OEM are the same as for a Piaggio X9
Fri May 21, 2021 10:57 am
2008 fuoco
2008 fuoco
Fri May 21, 2021 10:57 am linkquote
So you think there that good then
  DoubleGood Vespa Scarves
[ Time: 0.0354s ][ Queries: 22 (0.0147s) ][ Debug on ][ 156 ][ Thing Two ]
