@duane1 avatar
2005 et4
@duane1 avatar
2005 et4
I have p125X engine kitted to 177 with a Vape electronic ignition,
My spark plug cap keeps popping off.
I got a new plug wire\cap but it is a resistor type and can only get the resistor type plug without ordering online. I dont have the screw on end to the old plug.
Can I use both of these together without issues until the non resistor (with the plug end screwed on) comes
@rowdyc avatar
@rowdyc avatar
Having a resistor plug cap for an advance timing ignition is a good idea. The resistor plug cap can use a regular spark plug or a resistor spark plug. I'm running a Flytech ignition with a resistor plug cap and a regular spark plug. I may add a resistance spark plug after installing my SIP speedo.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Look inside the cap, last one I bought I was able to unscrew it and pull the resistor out. Made an equivalent size piece with aluminium foil and put it back together. I could only find the plugs I wanted in resistor type and cap in resistor type.
https://www.google.com/search?q=spark+plug+cap+resistor+removal&oq=spark+plugcap+remove+resistor&aqs=chrome.1.69i57j0i22i30j0i390l3.11898j0j7&sourceid=chrome-mobile&ie=UTF-8
[ Time: 0.0206s ][ Queries: 3 (0.0013s) ][ Debug on ][ 313 ][ Thing One ]
