Sat May 22, 2021 3:03 pm
1986 vespa px200e
1986 vespa px200e
Sat May 22, 2021 3:03 pm linkquote
ı have an 1986 px200e, ı was remove some parts a while ago and today ı assembled again but ı saw ı had an electrical problem.
The problem is my rear turn signals and headlights are not working, but my front signals (they are blinking when ı push the turn signal switch) and backlight (break light) is working, ı checked every cable but ı cant find the problem, do you have any idea where do ı need to check.
thats make me so sad everythings looking fine about cable but rear signals and headlight didnt work, please help me if you know the problem.
Sun May 23, 2021 5:03 pm
PX150E
PX150E
Sun May 23, 2021 5:03 pm linkquote
For the headlight, check that you have a good bulb. If bulb is good, check that you have 12V AC at the light socket.
For the rear turn signals, first clean the holes where the cowls pegs are inserted, and again, verify that you have 12V AC(if your model is without battery) or 12V DC if it has the battery. Does the tail light come on, or just the brake light?
  DoubleGood Vespa T-Shirts
[ Time: 0.0368s ][ Queries: 26 (0.0191s) ][ Debug on ][ 198 ][ Thing Two ]
