@grahamlml avatar
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
@grahamlml avatar
Put a new SIP clutch assembly into my 2T Stella today.
Same teeth as old one 21.
Pulling clutch in no noise and revving in neutral fine.
As soon as I let clutch out in drive it makes a whirring noise as I drive along not had chance do more than a 100 yards in first and second gear.
Could this just be new teeth wearing in with the drive teeth or do I need to worry.
@108 avatar
V range 50s
@108 avatar
V range 50s
Re: Clutch change
Sounds familiar...
Had the same problem... I thought it was a badly machined part and swapped it out for an OEM one, problem went away... but realised i actually installed the wrong size
Theres 2 sizes for the same teeth number (40 and 42mm) which is matched to the primary...
Oh I'm assuming its a cosa2 style clutch... and not sure its the case for 21 teeth though...
@grahamlml avatar
@grahamlml avatar
Thank you 108 I shall get chance to check later in the week.
[ Time: 0.0234s ][ Queries: 4 (0.0046s) ][ Debug on ][ 313 ][ Thing One ]
