@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
Was wondering, changed my gear oil and only got 4 ounces out of it and that doesn't sound right. Bike sat overnight and I didn't run it before dropping the oil , is that perhaps why ? I refilled the oil and started it and it seemed fine but I haven't ridden it yet.
@108 avatar
PX 200
@108 avatar
PX 200
What scoot is it?
When was the last time you filled it up?
4ounces sounds pretty low... if it was topped up in the past year, and it's a large frame vespa. Most likely you have a leak somewhere and if there's no oil everywhere, could be an oil sucker or clutch side seal leak...
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
108 wrote:
What scoot is it?
It is a large frame and there has been a drip leak, I haven't topped it up since last year when I changed the oil for the clutch problem. I just want to make sure if I drained it with oil cold it makes no difference as long as I drained all that came out and refilled to the point it was dripping out the overflow.
@108 avatar
PX 200
@108 avatar
PX 200
In my experience, and I'm pretty anal about it, I have paint mixing pots and pipettes to make sure I get a pretty exact amount... it doesn't make a difference draining it cold or warm.
I'm guessing it's just because it a pretty simple and small engine design.
There's no oil pump, oil filter, valve passages for the oil to collect in...
The leak is just coming out of the bottom of the crankcase?
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
Yes seems to be leaking kind of down the front of the motor cases seam, the engine is a new build with 340 miles on it.
@108 avatar
PX 200
@108 avatar
PX 200
You probably want to solve the leak... if it's only got 340 miles in it, sounds like the cases weren't closed properly (not torqued properly, failed gasket/surface, dirty cases surface) and you probably don't want that long term...
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
No I don't want that long term , it was built by a well known builder not myself. I will wait until I have my 500 mile breakin completed and get the jetting stabilized and then see what's going on.
@108 avatar
PX 200
@108 avatar
PX 200
Hope you can get to the bottom of it soon.
Try make sure you have enough oil for the gears, if not you'll have a lot of premature wear...
Even to the level of the filler hole, it actually isnt that much oil getting flung around inside of the gearbox.
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
Thanks I will keep that in mind.
@fng avatar
1960 Allstate VNA, 1962 VNB
@fng avatar
How much oil does a VBB/VNB hold?
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
Truthfully I have no idea how much oil a vbb is supposed to hold.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
180cc ... about 6 ounces
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
Ok sounds about right , so I lost 2 ounces of oil over a period of about 80 miles. Sounds worse than it is right?
[ Time: 0.0274s ][ Queries: 3 (0.0046s) ][ Debug on ][ 313 ][ Thing One ]
