Tue May 25, 2021 8:35 am
'81 Vespa P200e, '85 Vespa PX125e, '70 Vespa 90 basketcase
Tue May 25, 2021 8:35 am linkquote
Hi all,
Just trying to dial in my set up for my bike.
Px125e (switched to premix--removed autolube).
Dr180 kit
Mazz crank
20mm carb
Sip road two exhaust
Any recommendations on carb set up. Looking for a bit of punch and planning on taking this scoot on a long trip in July.
Thoughts?
Thanks.
Tue May 25, 2021 8:45 am
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Tue May 25, 2021 8:45 am linkquote
I've had success with a Stella with everything you listed. Stella's have reeds vs rotary so your perfect setup will be a little different but start out stock starter, idle jet, drill out the heart in the air filter and 160, BE4, 125. Obviously favor the conservative side of jetting as you'll be pushing it hard on your trip.
Tue May 25, 2021 8:49 am
Tue May 25, 2021 8:49 am linkquote
Noted. I already have a drilled out air filter.
I think my main stack is currently:
160/be3/115. Plus looks decent with my sito plus pipe. I'm replacing it with the sip exhaust once I receive it.
I can try the 125.
What's your top speed wot? 3/4 throttle?
Thanks.
Tue May 25, 2021 8:53 am
1963 VBB2T
1963 VBB2T
Tue May 25, 2021 8:53 am linkquote
I'm new to this tuning stuff but with everything I've been reading in here the Jack Stack is the key to start with 140/B5/mj .
  DoubleGood Vespa T-Shirts
[ Time: 0.0390s ][ Queries: 26 (0.0212s) ][ Debug on ][ 201 ][ Thing Two ]
