Wed May 26, 2021 10:13 am
Motovespa 150s lambretta li150
Wed May 26, 2021 10:13 am linkquote
Hi guys I have managed to get my engine running and diagnosed a damaged zues cdi many thanks to SALISBURY for the help. So now onto the next problem I have . My engine is a px150 2015 that I have fitted into my old motovespa. The engine was professionally built about 2 years ago but due to covid etc and work I have only just got round to fitting it in my scoot. The engine was built with a mallossi 177 cylinder and I have a sip road two pipe I am also still running the standard 20 /20 carb. This is my first vespa after having a lambreyta for 20 years and I find the carbs a little confusing if I am honest.
The engine fires up and idles great the idle screw is 2 turns out and the mixture screw is the same. My problem is as soon s the choke is off it dies instantly. I suspect the jetting is way out and have just removed everything this is what I have.
140 air corrector
115 main
52_140 idle
BE4 mixer.
Can anyone tell me please if anybof this could be my problem or suggest what would be a good start point.
Many thanks in advance Matt
Wed May 26, 2021 10:16 am
Wed May 26, 2021 10:16 am linkquote
140 air corrector
115 main
52_140 idle
BE4 mixer.
Debris in the idle jet or idle jet circuit. Start here first.
Wed May 26, 2021 11:03 am
Wed May 26, 2021 11:03 am linkquote
Many thanks will do that tomorrow.
What about the jets do they look ok
Thanks again
Wed May 26, 2021 12:28 pm
Wed May 26, 2021 12:28 pm linkquote
That setup is close enough. Very seldom can a jetting setup makes the motor shut off when choke is released. Start cleaning the carb like stated earlier and go from there.
Wed May 26, 2021 11:25 pm
Wed May 26, 2021 11:25 pm linkquote
OK thanks
  DoubleGood Vespa T-Shirts
[ Time: 0.0359s ][ Queries: 26 (0.0180s) ][ Debug on ][ 201 ][ Thing Two ]
