Upcoming Server Maintenance
Modern Vespa will be down for approximately 1 hour on Sunday, December 4th, starting at 9pm Pacific Standard Time
Wed, 26 May 2021 20:40:37 +0000
Wed, 26 May 2021 20:40:37 +0000 linkquote
⬆️    About 7w elapsed between posts    ⬇️
Tue, 13 Jul 2021 19:08:10 +0000
Tue, 13 Jul 2021 19:08:10 +0000 linkquote
Helpful hint wrap a rag around the top of the leg shield, steering stem area, to avoid having hardware disappear down the hole, resulting in multiple hours to retrieve the errant bit...
The rest of the story
I was installing a windshield the tube under the bars had some splatter which caused the nut/tapered lock to get jammed only part way in
I watched as the nut teeter on the edge of the abyss, before disappearing into the leg shield
About 4 hrs, NO BROKEN TABS !
[ Time: 0.0256s ][ Queries: 4 (0.0043s) ][ Debug on ][ 237 ][ Thing Two ]
