Helpful hint wrap a rag around the top of the leg shield, steering stem area, to avoid having hardware disappear down the hole, resulting in multiple hours to retrieve the errant bit...
The rest of the story
I was installing a windshield the tube under the bars had some splatter which caused the nut/tapered lock to get jammed only part way in
I watched as the nut teeter on the edge of the abyss, before disappearing into the leg shield
About 4 hrs, NO BROKEN TABS !
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
[ Time: 0.0342s ][ Queries: 5 (0.0101s) ][ Debug on ][ 313 ][ Thing One ]
