2009 Gts super 250ie
New to me 2009 GTS 250ie with 280km...thats right it's minty. Rode in city few times no issue . Gassed up and it over flowed everywhere ran an hour then stalled for over 60min. Started up and hot the 80km home. Did some reading and know about Evan. Second fill overflowed again would not start for an hour at the pump. Another long ride got stranded for an hour again,lost power in a turn this time. Did more reading and found out about fuel pump. Anyone can share experience on Evap or fuel pump? I have called local dealer to check about recall on pump but I don't think I'm on it. I can replace pump myself but if it's Evap I don't want expense. Ideas would be appreciated.
Mine
Mine
'06 GTS 250; '18 GTS 300; '21 Liberty 150
You can easily bypass the evap, this might be relevant:
EVAP Hose Removal
I just did my second fuel pump replacement and its a bit of a job.
(did it 2x cuz I don't learn, not cuz it was necessary)
For me the big thing was figuring out how to support the vespa while not having it on the center stand. I did a combo of wheel chock / jack stands / use of hydraulic floor jack but the whole setup was a bit dodgy / unwise. Second time around maybe 2 hours start to finish. First time took better part of a day.
HTH
[ Time: 0.1005s ][ Queries: 5 (0.0928s) ][ live ][ 343 ][ ThingOne ]
