Vespa VNB 1962
Vespa VNB 1962
Hi - has anyone had any success using 12v led festoon bulbs to replace 6v festoon bulb on an early model vespa. Keep blowing tail light bulbs and looking for options,
@chandlerman avatar
Innovator
187 Days Since Last Explosion
Innovator
@chandlerman avatar
You're running a 6V AC system, right?
Unless you have a purist attachment to keeping it "authentic," what you probably want to do is install a voltage regulator.
The early Vespa's used what was called a "balanced" AC system, where the load on each circuit was supposed to be enough to prevent voltage spikes. It was, I assume, a cost and supply chain risk control measure, but a terrible engineering solution because any failure resulted in a cascade of blown bulbs, which is what you're probably experiencing.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Increasing the voltage won't help. You might try increasing the wattage or, like Chandler says, get a regulator.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I tried that with my VBB When I first got it. It would still blow the bulbs eventually. I finally just gave in and got the regulator.
If you're blowing bulbs, let me go out on a limb and offer my advice: don't look for more expensive bulbs. Sort the issue at hand before blowing more expensive bulbs. That is, treat the cause, not the symptom.
Measure your voltage, report back.
[ Time: 0.0087s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
