I have an opportunity to buy either a new 2019 Vespa GTS 300 or a 2021 Vespa GTS 300. Keep in mind they are both new. Any thoughts, opinions or recommendations.
Interesting topic! 2019 should be an HPE euro 4 when the 2021 HPE euro5. The shape of the wheels will tell you.
In this case they don't have exactly the same power distribution even the max power might be different. The euro 5 regulation are drastic and do stifle the engine. Weight also should be higher as new exhaust with another catalytic converter. Just for info when servicing my 2020 euro 4 Racing Sixties my mechanic showed me that euro 4 and euro 5 have different settings for the valve adjustment. All this being said and pf course it's my personal taste, I would choose the 2019 with a discount and all liquids renewed. Keep us posted! And more info about the different models would surely be useful. Thanks
Positive
Posts: 11584 Location: Hermit Kingdom |
Posts: 8643 Location: Batmania aka Melbourne, Aus |
are they both HPE? iirc early 2019 was not HPE
also, "the shape of the wheels" for determining euro4 vs euro5 depends on the country. here in AUS we got the 'new wheels' in 2019 yet the US didn't get them until end of 2020 (called the 2021 model i think) why is the 2019 still new? is it really? has it been sitting in the show room for that long? seems odd ... have a close look at the exhaust ... the euro5 has an extra bulge between the silencer and the engine. it also has a clamp where the pipe meets the silencer |
steelbytes wrote: are they both HPE? iirc early 2019 was not HPE also, "the shape of the wheels" for determining euro4 vs euro5 depends on the country. here in AUS we got the 'new wheels' in 2019 yet the US didn't get them until end of 2020 (called the 2021 model i think) why is the 2019 still new? is it really? has it been sitting in the show room for that long? seems odd ... have a close look at the exhaust ... the euro5 has an extra bulge between the silencer and the engine. it also has a clamp where the pipe meets the silencer Anyone knows of the other engine differences -but the valves adjustment as I mentioned-? |
A 2019 model in the U.S. will not be an HPE model. Lots of opinions on whether this is good or bad. Comparing similar trim levels, I would expect at least a $500 price difference between the two choices.
FWIW, I had a 2015 and now have a 2021 300 HPE and I think that there is a real power improvement with the HPE.
2023 GTS300, 2021 Sprint, 2024 BV400
Posts: 243 Location: Bama |
When doing my research and deciding on a 300 or 300 HPE, price was a definite variable. I finally decided on the extra power and latest technology but that also comes with a dramatic increase in maintenance schedules. Worth considering if you haven't already.
In the US, the 2019 GTS isn't the HPE engine. I notice the difference with the performance of the 2020 HPE... not a big difference, but noticeable when ridden side-by-side. I would assume some kind of discount on the 2019?
I decided on the 2019 Vespa gts 300 with the 21.2 hp (15.6 kW) @ 7,750 rpm engine. I saved over $1100 dollars. I use to have a 2015 with the same engine so I'm sure I won't be disappointed.
Thank you all for your input. Bob |
Lobo104 wrote: I decided on the 2019 Vespa gts 300 with the 21.2 hp (15.6 kW) @ 7,750 rpm engine. I saved over $1100 dollars. I use to have a 2015 with the same engine so I'm sure I won't be disappointed. Thank you all for your input. Bob |
GTS 300ie
Posts: 1755 Location: Sunshine Coast, Australia |
Posts: 900 Location: somewhere deep in the back of the garage...Burlington ONT. |
Retro Scoot wrote: When doing my research and deciding on a 300 or 300 HPE, price was a definite variable. I finally decided on the extra power and latest technology but that also comes with a dramatic increase in maintenance schedules. Worth considering if you haven't already. When improvements come with increased maintenance requirements, are they really improvements? As someone who has been at it long enough to remember high performance two strokes requiring points and condensers every 2 or 3 thousand miles and sparkplugs at every second intersection I really am willing to give up a little performance to enjoy the obscenely long service intervals some modern machines offer.
Positive
Fritz Katzenjammer wrote: Just wondering: When improvements come with increased maintenance requirements, are they really improvements? |
