Gts300, p210, gp200, ts1 225.
Any ideas on this? 2010 gts 300. Cut out and will not start. Cranks over but will not fire, there is a spark and fuel is coming out of the injector. Fitted a new battery and regulator as there were charging problems (started fine afterwards but then this problem started) Tried blue and brown keys but it still just cranks over without firing. Checked the valve clearances when i gave it a full service roughly 1000 miles ago. Im stumped!
@appleman avatar
2005 GT200, 2018 GTS, 2022 GTS, 1965 Allstate
@appleman avatar
Belt in good shape?
All good, new belt fitted with a polini variator when I did the service.
2022 Honda PCX 150A, 2018 GTS300 [sold] & 2015 GTS300 Super [sold]
Wiring short? Starter? ECU?
@ks7877 avatar
@ks7877 avatar
I have not encountered this problem, so I'm no help I'm sure more experienced folks here will be able to offer useful suggestions.
I'm just chiming in to say Hello and Welcome to Modern Vespa, gp200ts1. Hope you get things sorted and back on the road soon!
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
Welcome to MV! Post some pics, check your cutoff switch, then your battery & connections.
@fishfingers avatar
Stella, GTS 300, Vespa p200e
@fishfingers avatar
Check the spark pluug and cap.
Right, plug, lead and cap replaced. Plug sparks great when out of head.
Fuel pump works great and the injector is spraying fuel.
Cranks over well so it's not the starter motor.
Kill switch stops it cranking so that's working.
Battery is new and fully charged.
Air filter is clean.
Belt and rollers are great as they were only changed 1000 miles ago.
No faults showing when the diagnostics are run.
Valve clearances are spot on.
This is driving me demented as I can't suss it.
Sounds like you've covered all the bases. An engine needs air, fuel, and spark. You say the plug sparks great when out of the head -- what did you ground it to when you were testing that?
Is it possible the ground lead to the side of the engine is faulty?
Funnily enough I noticed that lead was loose so I sorted that but no change. Grounded it to the head cover.
Okay, good. But now is the engine flooded from repeated start attempts?
Bollocks, the ht lead had become trapped and was shorting. It was still sparking at the plug but was shorting out stopping it from running. Fixed now.
w00t!
[ Time: 0.0112s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
