Hi All,
Looking for suggestions on what you would recommend using to clean up engine exterior, etc.
I plan on using brushes first to remove what I can. Then to remove the grease and grime, what works best? I've seen people use brake cleaner, simplegreen, soapy water, etc.
Also what should I be covering/holes plugged during cleaning?
Thanks![/img]
