Sun Jun 06, 2021 1:29 pm
lml 2t 150 with sidecar, Vespa px cutdown 125cc
Sun Jun 06, 2021 1:29 pm linkquote
I have just acquired a bare Vespa px frame and engine non electric start from 1980 and slowly going to build it into a non battery non indicator model but with the later electronic ignition electronic.
Is there a wiring loom specific without indicators wire in from that period or just remove the unnecessary wiring.
I am also a little confused over the components needed as appears there are different types of stators and cdi/coil packs. I presume 3 pin regulator / rectifier is the correct type?
I have experience of wiring with dc circuits on bikes about 4 decades ago but not ac.
Even a decent book would help.
Many thanks in advance
Mon Jun 07, 2021 6:50 am
Mon Jun 07, 2021 6:50 am linkquote
I'm not too familiar with Euro P's and PK's as they are different then the US models.
It seems the no indicator P's had a 6V system with points and another with a CDI.
With a no battery P wiring loom https://www.sip-scootershop.com/en/product/wiring-loom_86100000 I'm sure you can tape up/remove the extra indicator wires but there are some more wire from the removed flasher that needs taping up or joining. http://www.scooterhelp.com/electrics/wiring/VSX1T.no.battery.pdf. It uses a 3 prong regulator. To me this seems easy.
You can also go with the P no indicator wiring loom that uses a CDI https://www.sip-scootershop.com/en/product/wiring-loom_87035100. That would need a 12v conversion by adding a 3 prong regulator and changing wiring. This seems more difficult to me and I don't know what type of handlebar switch would be used for 12V on this 6V loom. http://www.scooterhelp.com/electrics/wiring/VSX1T_Euro_6V_CDI.pdf Maybe the 6V handlebar switch can be converted, too.
Someone that has deleted their P indicators may pop on and provide better detail.
Good luck!
Mon Jun 07, 2021 7:03 am
1958 Allstate Super Cruisaire 2005 70cc Yamaha Vino
Mon Jun 07, 2021 7:03 am linkquote
My VNA wiring upgrade came with wires for signals. You can either just remove the wires or tape them off.
Mon Jun 07, 2021 12:06 pm
Mon Jun 07, 2021 12:06 pm linkquote
Thank you very much for the info, its been a great help
  DoubleGood Vespa T-Shirts
[ Time: 0.0353s ][ Queries: 22 (0.0166s) ][ Debug on ][ 156 ][ Thing Two ]
