@billrush avatar
@billrush avatar
For my headlight modulation project research, I need to know what bulb I have. I would have sworn that Robot at Scooter West said it was incandescent. I googled it and got HS1 Halogen and thought it was wrong. Then I found it listed in my owners manual as an HS1 Halogen. I've attached a photo of the bulb in my scooter. Sorry about the quality. I know this is raw nube stuff.
I don't expect to ride much at night. Again, I think Robot said it would not be upgraded to european LED's because the 50 "draws power from the magneto"
Has anyone done the LED conversion?
Thanks much
@jkj-fz6 avatar
@jkj-fz6 avatar
Same thing. A "halogen" bulb is an incandescent bulb that's filled with halogen gas.
@billrush avatar
@billrush avatar
Is my HS1 headlight bulb the same as an H4? Googling gets me different answers. Do they have the same base?
@attila avatar
@attila avatar
If I remember correctly, the HS lamp heats less than an H lamp ... and they have a different socket base.
@jkj-fz6 avatar
@jkj-fz6 avatar
To my eye HS1 and H4 bases appear to be the same but the filaments look different. According to Google, HS1 is 35W and H4 is 55W. I don't know the difference between HS1 and H1, if there is any,
@billrush avatar
@billrush avatar
This link seems to explain the differences between the Hs1 and H4.
https://ecosportdiyseries.com/2019/10/07/replacing-h4-with-an-hs1-bulb/
I finally took the chrome headlight ring and cover off to access the bulb. It is an HS1. From the bulb: Osram 64185 which is a HS1 halogen. $15.25 on Amazon. I watched the scooter west video on converting the primavera 150 to LED to see Robots great description on how to take it apart.
You tube link
Not hard to follow.
@attila avatar
@attila avatar
They have the different attack as I said, similar but not the same.
@billrush avatar
@billrush avatar
My HS1 pictured. Lower watts and wider center pin that an H4. So according to the link I posted, H4 fits HS1 mounting fixture without modification. But HS1 in H4 mounting fixture requires bending of the center pin. And HS1 is less bright. Well documented in this link.
@attila avatar
@attila avatar
... and therefore being less bright it heats less, as already mentioned but ... there is a reason and I tell you, an H4 would have baked the reflective part and the transparent part (if made of plastic). The HS is designed for small headlights.
[ Time: 0.0095s ][ Queries: 4 (0.0028s) ][ live ][ 343 ][ ThingOne ]
