berto wrote:
There's a gasket under there... make sure you order a new one and replace while you're in there.
Just curious, what happened that it failed? Cracked/split? Or the brass connector pulled out?
Thank you! Got the gasket. Should I add form-a-gasket when I install?
The boot had a tear. Bike had been sitting for five years when I bought it. I've systematically replaced nearly every rubber part. I finally got it running, and I may have clamped the manifold down too hard and cut/weakened it. It gave out on a short ride this weekend. I think it was a combination of my error and old rubber!
