Electtrica
Electtrica
Hi all, first post here. Purchased an elettrica a few days ago. It's a 50 with blue trim. I wanted a 70 but in N/A they are only available in yellow trim which we did not care for. Most of my around town larger roads are 50km/h, therefore people are right up your rear or passing you. Another 10km/h would be great. I'm positive the speed limiter is software governed, has anyone found the hack to bypass or raise this. It's a beautiful quiet machine and now sits beside a Lambretta 1964 TV175.
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
Welcome to MV!
I have zero experience with the Elecrtrica. I'm not sure, but I don't think it is intentionally limited, that's just the way it is designed. Someone will come along soon to confirm or refute this, soon.
Post some pics of your new ride. PLEASE!
@pbcoole avatar
GTV300
@pbcoole avatar
GTV300
I would second that guess, but without any real basis in knowledge.
I'm holding out for a long range, highway speed electric Vespa. I'm guessing those are still fifteen or twenty years down the road.
Maybe I should start stashing $700 a year away, (guessing on inflation).
@attila avatar
@attila avatar
Welcome to MV from Latina, central Italy.
Lambretta 175 TV, the fastest Lambretta.
Electtrica
Electtrica
Definitely software as top speed is too accurate, always 48km/h. Battery and electric motor have more than enough for a little extra juice.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Pictures pleaaaaase!
Electtrica
Electtrica
Here you go.
Electtrica
Electtrica
Never mind the cable, it's sitting under this.
I recognize the lathe and I have the big brother to the cabinet it's sitting on. Whalen, I think.
The Lambretta is pretty nice, too!
Electtrica
Electtrica
Here is the sweet shot
Ooh, and a Hazet cart too! I have one of those as well.
Are you a member of Garage Journal, by any chance?
Vespa Elettrica 70km
Norm01 you missed the trick I'm afraid you could have bought the yellow 70km model and swapped the trim as an aftermarket purchase .
Electtrica
Electtrica
Not the seat trim, unless you want to spend big $$. Wheel rims are trimmed out too, I'm sure they are also not cheap.
Don't think you'll be able to hack the software , the wheel trim is just an adhesive and i don't think a seat is big bucks / pounds.
@safis avatar
@safis avatar
Different part codes for motor, ECU / Controller, Battery, main loom, etc. so I don't think it's only a software restriction...
[ Time: 0.0101s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
