So I went to upgrade my signal lights to LEDs on my 2006 Typhoon and used the directions from Pedparts:
https://www.pedparts.co.uk/blog/piaggio-gilera-led-indicator-flasher-relay-upgrade
I have done a flasher upgrade on other motorcycles with no problems before so this was a new one.
When I signal all 4 lights go on, with the side selected full brightness and the opposite side dimmer. Note that the dash indicator doesn't light up. When I select the other side with the switch the opposite occurs. They do blink at the proper rate so doesn't seem that the flasher is the issue.
I tested continuity between the positive signal leads out of the switch and they have continuity which makes sense because they both feed to a single dash indicator light.
I reinstalled incandescent lights and it works fine with the dash light blinking.
It seems the LEDs are such a light load that it is sending power through the instrument cluster to the opposite side light. I tried flipping the polarity of the LEDs with no change.
Would installing a load resistor help. It's really bizarre behavior.
Also since I have a parts bike I tried swapping signal switches and instrument clusters with no effect. Even tried 2 different brands of LEDs.
