Greetings,
2007 Fly 150. Rear brake engages on left turn. Left brake lever felt strange and I heard clicking, so I took off the cover again.
On a prior post, someone suggested the cable is too short. However, as I look at the way the cable is routed (see photo), the cable crosses over to the right side of the bike and then follows the path underneath to the drum.
So the cable appears to be shortened by the routing.
The other headset cables go through the cable tie to the right of my hand in the photo.
I'm a noob. I'm figuring everything out through this forum and some amazing videos. I know nothing about brakes. So before I re-routed the cable, I thought I should ask.
It would seem that the cable should go on the right side with the others and then I can adjust the nuts as needed to get the right travel.
What say you?
Thank you in advance.
