The SS180 clutch that I have has a large brass bushing that the gear cluster spins on.
I've noticed in the parts book that I have shows there are 40 needle bearings where this brass bushing is on mine. The parts book indicates these needle bearings are for both the GS and the SS, but it shows no option for a brass bushing.
Were there two different versions of this clutch? Are the bushing and needle bearings interchangeable? In other words, could one remove the bushing and install the 40 needle bearings in place of the bushing?
Or is this bushing in my clutch a bodge from the past owner?
Any information is appreciated.
Hmmm...parts book definitely shows two versions but doesn't make clear which version goes with what model?
*scratches head*
Will be watching for more learned replies...
I found a bit more information. Scooterwest offers an SS180 clutch rebuild kit that has a caged set of needle bearings they claim can replace the bushing. They say Piaggio put the bushing on later models (I assume SS) to cut costs.
@lynnb avatar
1963 VBB2T
@lynnb avatar
1963 VBB2T
I would think the caged needle bearing replacement would be less friction than the brass bushing.
Yes, and maybe thus quieter. From what I've found out, the bushing can be removed and replaced with a set of needle bearings.
There always seems to be some odd ball thing with these SS and GS engines. It's as if a renegade engineer at Piaggio was let loose in the early 60s. I like it though. 🤪
On a side note, does anyone know if SS/GS clutch parts are interchangeable? Specifically, I'm wondering if a GS back plate can be used with an SS gear cluster, SS basket, and SS spring cups. My back plate is toast (old bodgism) so I want to obtain a GS back plate and use it with all the other SS bits I have.
@danie avatar
'57 VN2, '70 180 Rally, '80 P150X, '80 P200E, '13 GTS300
@danie avatar
According to the SIP website, both clutches are interchangeable.
I appreciate that. No offense to SIP, as they are a great source of parts, but I've been misled by their product descriptions enough times to be somewhat reluctant to believe what they write.
[ Time: 0.0102s ][ Queries: 3 (0.0027s) ][ live ][ 343 ][ ThingOne ]
