1961 Vespa VNB2T / 1983 P200E / 1974 Sprint Veloce
Anybody can help identify this engine?
@greasy125 avatar
@greasy125 avatar
that appears to be an early P125/150, however the photo leads me to suspect it's been used for some type of industrial application. so, kinda, like all bets are off.
run the motor number and see what comes back
but looks like some farmer bodge action going on here.
@hjo avatar
@hjo avatar
If I were to take a wild guess, I'd say an Allstate Sprint from the 1960s?
The metal cylinder shrouds were used on 1960s bikes, and it has a 10" wheel.
And it ended up driving a belt for some strange creative use. More likely from Sears than a Vespa dealer in a city.
@greasy125 avatar
@greasy125 avatar
look at the flywheel, there's no bolts holding it on which leads me to lean more towards early P series. along with that 10" wheel that's been repurposed. probably for a belt drive and the welded kickstart lever. also, it's got the later hub- not the 8" with four or a super style. not saying that couldn't or wouldn't have been updated, butttt...
if we loop back to the metal shroud, that screams SEA origin, along with some janky nuts and a 10" on something that should have, maybe an 8? and anybody that was adapting something wouldn't go thru the time or the trouble. they're just gonna use what the have on hand with the least amount of work necessary to get up and running.
unless it's free? hard pass. too questionable.
[ Time: 0.0098s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
