ph
⚠️ Last edited by phaskins on UTC; edited 1 time
I have never carried a spare 30 amp
ph ⚠️ Last edited by phaskins on UTC; edited 1 time
Positive
Posts: 5707 Location: Santa Cruz California |
Phaskins, you know why the fuse blew? 30 amp fuses don't blow easily. There has to be at least 30 amps of current for them to blow and that's a lot of current and would easily vaporize small wires. It's be worthwhile looking around the bike to see if you see any blacked/charred insulation on heavier gauge wires. Perhaps someone else will have a more detailed suggestion.
Miguel |
RIP
Posts: 8291 Location: Latina (Italy) |
Miguel wrote: Phaskins, you know why the fuse blew? 30 amp fuses don't blow easily. There has to be at least 30 amps of current for them to blow and that's a lot of current and would easily vaporize small wires. It's be worthwhile looking around the bike to see if you see any blacked/charred insulation on heavier gauge wires. Perhaps someone else will have a more detailed suggestion. Miguel |
Posts: 3766 Location: East Anglia, UK |
I agree that sometimes fuses just blow. This happens because of age related vibration, corrosion, fatigue from carry load. After all, the fuse link is only a very light alloy. That's why it's a great idea to carry some spares.
Posts: 46053 Location: Pleasant Hill, CA |
Fuses are just very dark light bulbs. They will eventually fail of old age. The main reason is due to fatigue from expansion/contraction heat cycles. Examination of the dead fuse can often determine if something shorted out (smell, evidence of extreme heat) or just failed of old age (you can hardly see the gap in what otherwise looks like a good fuse).
Positive
No smell and it appears good though two of the contacts are showing open compared with the new fuse. I'm chalking it up to age until proven otherwise.
Posts: 4765 Location: Twin Cities, Minnesota |
