@swiss1939 avatar
@swiss1939 avatar
Reposted with permission, from FB
https://www.facebook.com/permalink.php?story_fbid=346887065955145&id=100019015620859
Main colors thread
Here are a few values found from scanning the Vespa Tecnica swatches. This is what Scooterwest does when you order from them. Kristian Storli actually scans from original parts. I think this is the preferred method.
(cont.)
Azzurro Cina 1.298.7402
Giallo Arancio 1.298.2916
Grigio Biaccia 1.298.8714
Avorio 1.298.3909
Avorio 1.298.3909
Chiaro Di Luna Metallizzato 2.268.0108
Arancio 1.298.4907
Arancio 1.298.4907
Grigio Metallizzato 15005
Rosso 1.298.5847
Rosso 1.298.5847
⚠️ Last edited by swiss1939 on UTC; edited 4 times
@swiss1939 avatar
@swiss1939 avatar
Vespa Colour Codes Cracked on how Colin Judd cracked the Max Meyer PPG conversion codes.
"Vespa
5-digit codes
The 1st digit is merely a color group: 0 for metallics; 1 for whites; 2 for yellows; 3 for browns; 4 for oranges; 5 for reds; 6 for greens; 7 for blues; 8 for greys, and 9 for blacks.
The next 3-digits should be easy to match in a PPG catalog. Though since the bastards moved the online catalog from the public http://www.ppgcarpaint.com/colorsv2.php to the secure https://buyat.ppg.com/colorweb/ppgna/ it's hard to check on.
Ignore the M at the end.
8-digit codes
The 8-digit code was first used on the 1960 Vespa 125. Specifically, it used the Light Blue-Grey: MaxMeyer 1.298.8840.
The first digit is going to either be a "1" (single-stage paint) or "2" (metallic paint).
The second three digits is a batch code, "268" for Maxi-car; "298" for Bi-lux.
The 5th digit is merely a color group: 0 for metallics; 1 for whites; 2 for yellows; 3 for browns; 4 for oranges; 5 for reds; 6 for greens; 7 for blues; 8 for greys, and 9 for blacks.
The final 3-digits should be easy to match in a PPG catalog. Though since the bastards moved the online catalog from the public http://www.ppgcarpaint.com/colorsv2.php to the secure https://buyat.ppg.com/colorweb/ppgna/ it's hard to check on. (Some of their old pages are still accessible through the Wayback machine at the Internet Archive.)
1963 Vespa 50
Green: MaxMeyer 1.298.6301
Inside Gray Primer: MaxMeyer 8012M
1963 Vespa 90
Baby Blue: MaxMeyer 1.298.7210
(Fork, Hub, Flywheel, etc.) Aluminum: MaxMeyer 1.268.0983
Inside Beige Primer: MaxMeyer 3000M
1964 Vespa 50
Red: MaxMeyer 1.298.5847
Stone White: MaxMeyer 1.298.8710
Red/Stone White (Fork, Hub, Flywheel, etc.) Aluminum: MaxMeyer 1.268.0983
Green (Fork, Hub, Flywheel, etc.) Gray: MaxMeyer 8012M
1965 Vespa 50 N
1966 Vespa 50 N
Silver: MaxMeyer 2.268.0108 <li>(from V5A1T 092877-) Blue -White in then: MaxMeyer 1.298.7400
(from V5A1T 092877-200,000) Monza Red: MaxMeyer 2.298.5850
(from V5A1T 140366-200,000) Green-White: MaxMeyer 1.298.6303
(from V5A1T 200001-) Green Apple: MaxMeyer 1.298.6302
(from V5A1T 200001-) Navy Blue : MaxMeyer 1.298.7305
(from V5A1T 200001-) Turquoise: MaxMeyer 1.298.7240
(from V5A1T 200001-) Yellow: MaxMeyer 1.298.2902
1965 Vespa 90 SS
Peacock Blue: MaxMeyer 1.298.7220
(from 1965-1968) Monza Red: MaxMeyer 2.298.5850
(from 1968-) Metallic Red : MaxMeyer 2.268.5802
1966 Vespa 50 L
Yellow-Orange : MaxMeyer 1.298.2916
(from V5A1T 500,001-540.000) Blue-Gray: MaxMeyer 1.268.7114
(from V5A1T 500,001-540.000) Green Apple: MaxMeyer 1.298.6302
(from V5A1T 500,001-540.000) Shocking Rose: MaxMeyer 1.298.5801
(from V5A1T 540.001-) Blue-White: MaxMeyer 1.268.0110
(from V5A1T 540.001-) Ivory: MaxMeyer 1.268.3901
(from V5A1T 540.001-) Yellow: MaxMeyer 1.298.2902
1968 Vespa 125 Primavera
Orange (1974-1976): MaxMeyer 1.268.5130
White: MaxMeyer 1.298.1715
1969 Vespa 50 Special
Chromium Yellow: MaxMeyer 1.298.2933
Coral Red: MaxMeyer 1.298.5811
(from 1972) Red: MaxMeyer 1.298.5847
(from 1972) White: MaxMeyer 1.298.1715
(from 1973) Racing Red: MaxMeyer 1.298.5806
(from 1975) Katmandu Red: MaxMeyer 1.298.5875
(from 1975) Tenerife Red : MaxMeyer 1.298.5870
(from 1976) Coral Red: MaxMeyer 1.298.5880
1969 Vespa 50 R
(from 1970) Silver: MaxMeyer 2.268.0108
(from 1970) Turquoise: MaxMeyer 1.298.7240
(from 1970) Yellow: MaxMeyer 1.298.2902
(from 1972) Blue : MaxMeyer 1.298.7490
(from 1972) Chromium Yellow : MaxMeyer 1.298.2933
(from 1973) China Blue : MaxMeyer 1.298.7402
(from 1973) Orange: MaxMeyer 1.298.4907
(from 1974) Amaranth: MaxMeyer 1.298.5835
(from 1974) Blue : MaxMeyer 1.298.7450
(from 1975) Racing Red: MaxMeyer 1.298.5806
(from 1975) Versaille Beige : MaxMeyer 1.298.2580
(from 1976) Navy Blue: MaxMeyer 1.298.7275
(from 1976) Texas Yellow : MaxMeyer 1.298.2935
1969 Vespa 50 Elestart
Blue: MaxMeyer 1.298.7490
Silver: 2.268.0108
1976 Vespa 125 ET3
Blue-Grey: MaxMeyer 1.298.7228
Red: MaxMeyer 1.298.5632
Flywheel, Hub cap, Front Suspension: Opaque Black
http://scoot.net/faq/Paint_codes
@swiss1939 avatar
@swiss1939 avatar
@swiss1939 avatar
@swiss1939 avatar
(cont.)
@swiss1939 avatar
@swiss1939 avatar
"Photo 1 - 2x (2 pieces) Piaggio quality control slip / slip, which were applied inside the frame cockpit, left side. For small wasps 50/125 (50 Special 50R 125 spring, and ET3) ONLY the excellent preserved ones have it N '1 For wasp with pastel color "BODY PAINT" N'1 For wasp with metallic color METALL PAINT"
(cont.)
[ Time: 0.0085s ][ Queries: 4 (0.0025s) ][ live ][ 339 ][ ThingOne ]
