Gts 300ie and vespa lx125 3v
Hi, today i took scooter on a 200 mike round trip. First time in a year i have taken it out on a long run, i do hiuse it daily around town.
It seemed to struggle to go faster than 60 mph. It did manage it but not how i remember. Fuel consumption has deteriorated a bit too.
Before i put into a shop i was hoping someone could point me as to what sort of things to look at first. Its a 2015 gts 300, 22,000 miles.
Of course it could be just my imagination and possibly the wind
@willie_b avatar
@willie_b avatar
Curious if you've ever serviced the belt and weights or had a look at your variator? These items deteriorate with time and diminish performance. Maybe some old gas as well, but wind will scrub speed
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Service history ? Spark Plug , air filter , valve clearance check and as mentioned transmission .
It has been regualry serviced. Belt rollers changed at 13k. Only change has been odyssey exhaust fitted (which seems loud even with both baffles in) new exhaust gasket fitted last week. One thing i have noticed is throttle seems to have more play than when first got it, so naturally you would need to turn more to getcsame effect. Only thing i dont remember ever having done is valves.
I have not hot anyone to compare with, but last year, i did a long trip during lockdown, no wind and i never went below 75mph.
Msybe i have just worn roller s down tje way i ride.
Can you check wear and tear on these without taking side casing off?
@willie_b avatar
@willie_b avatar
I don't know your exhaust, and with this said, a poor designed exhaust raises the octave but diminishes performance. Try fitting your stock exhaust to see if things improve
Ill try exhaust first.... So does anyone know how to inspect the belt and rollers
@grouper avatar
2020 GTS 300 hpe Touring
@grouper avatar
Check out Robot's videos on YouTube.
When was the new exhaust fitted? If it is a relatively new addition, it's highly likely that this is the culprit if the bike wasn't tuned on the dyno afterwards.
Edit: just noticed you said the valves have likely not been checked. Absolutely MUST check them as that could be the issue too.
⚠️ Last edited by Stromrider on UTC; edited 1 time
22k on it and last service was at 13k, hmmmmmmm
ya think a service is alittle over due?
@attila avatar
@attila avatar
+1
I have tried to book a gull service in, a two month waiting list.
Changed exhaust to stock exhaust tonight and will test it tomorrow. I did notice that exhaust wasn't tight around manifold despite keep on tightening bracket.
Dealer says some people have complained exhaust loses power... So that is possibility.
By the way i have changed oil, cleaned air filter ever 6000 miles. Belt and rlers changed at 14 000 miles, and still wete good to go
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
So you have 8000 miles on current belt & rollers ?
If so then it's getting near to replacement time again ( 9000 miles ) .
I discovered the issue. Turns out after i put stock exhaust back on comfortable 75 again, who'd have thought
2019 GTS 300 HPE w Malossi
what after market / sport exhaust did you have? and did it have a catalytic?
more likely this ^^
andrew5343 wrote:
tightening bracket
umm, what bracket? did you mean the t-bolt clamp?
I bought an oydessy slip on. Used supplied gasket and bracket. Fine round town but on long run it didn't jold up. Looks good though
This is my scooter and oydessy exhaust
[ Time: 0.0104s ][ Queries: 4 (0.0041s) ][ live ][ 343 ][ ThingOne ]
