Created article What are all the Forum Awards & How do I get them?
(This message was automatically generated)
Positive
Here are some reasonably-sized versions of the award artwork. I'll leave it up to berto as to whether to include it in the article or not.
jess wrote: Here are some reasonably-sized versions of the award artwork. I'll leave it up to berto as to whether to include it in the article or not.
Positive
Hmmm. Might have broken something. When was the last time an article got successfully edited?
(There is no large artwork for the TP award. Plus, we don't talk about it).
Positive
I was able to edit the existing article, and added the word "test" at the bottom. No issues. If you do have the text you tried to post, can you stick it in a post here on the discussion side? If it doesn't post here, there's definitely something wrong with it, though not sure what yet.
jess wrote: I was able to edit the existing article, and added the word "test" at the bottom. No issues. If you do have the text you tried to post, can you stick it in a post here on the discussion side? If it doesn't post here, there's definitely something wrong with it, though not sure what yet. I've attached the html and SQL, if it helps.
txt
522kb
txt
522kb
Testing 6:
(Judy's) Red Toaster -- Posthumously awarded to our very own Judy Rossman in remembrance of her contributions here. An homage to her long-standing red toaster avatar.
Okay, the problem is with the name of the attachment that's already been uploaded. It gets converted to an attachment tag (instead of a url) along with the original filename, which included an apostrophe. The apostrophe isn't getting escaped properly, leading it to barf on the SQL.
So a temporary fix is that I've taken the apostrophe out of the name of the original file upload -- if you quote my post above, you'll see an attachment tag, along with the name of the file, sans an apostrophe. The correct fix is to figure out at what point that apostrophe needs escaping. It obviously made it into the attachment database with no problem -- my guess is that the conversion of an URL to an attachment tag needs some attention. |
Oh, and you should be able to repost now. If you get another error, there's likely another apostrophe somewhere.
Okay, the correct fix is now also in place. Apostrophes in the filenames of attachment tags are now correctly escaped, and shouldn't produce any more errors.
Thanks much for pointing out this problem!
Positive
jess wrote: Okay, the correct fix is now also in place. Apostrophes in the filenames of attachment tags are now correctly escaped, and shouldn't produce any more errors. Thanks much for pointing out this problem!
Positive
jess wrote: New award artwork. This is the "Broken Piston Award".
Positive
berto wrote: @jess thanks! I'm on it! (later today) |
jess wrote: No hurry at all. Just wanted to make sure you knew there were updates.
Positive
berto wrote: Looking at the wiki page makes me think: I wonder if there could be a way to search members by award? For example golden toaster holders are "vanishingly rare", but there's no easy way (I know of) to learn who they are.
Positive
Just a heads up, there will likely be a bunch more artwork coming shortly. I'm replacing a whole bunch of the awards with new versions.
jess wrote: Just a heads up, there will likely be a bunch more artwork coming shortly. I'm replacing a whole bunch of the awards with new versions.
Positive
Here are the new versions. Sorry for the repeated changes, I wasn't entirely happy with the last versions. These are a bit more on-point.
jess wrote: One more, just released: |
berto wrote: Is this for a new award? Otherwise, I can't say I'm quite sure which one it maps to MV Jester Award for znomit |
jess wrote: I also updated the MV Entomologist art from [MVFR] POLL: What should Jess fix next? (Post 2670008), given it seems to be in use now.
Positive
berto wrote: I also updated the MV Entomologist art from [MVFR] POLL: What should Jess fix next? (Post 2670008), given it seems to be in use now. |
berto wrote: adding some images for coffee membership tokens |
Birdsnest - it looks like you added a section for Hams on the awards page, which is great! But is there an actual award for this? I'd like to add a Ham image, if one exists. I haven't seen a member have an actual icon, although I know it's been mentioned many times on the NSM side.
Ideally, do you also have a link to an MV thread where a Ham award was given? |
Posts: 8390 Location: Batmania aka Melbourne, Aus |
