Is my HS1 headlight AC or DC.
Posts: 838 Location: Naples Florida USA |
S150 '09, Beo 500ie '08
Posts: 1573 Location: Bermuda |
If the headlight comes on:
- when you turn the ignition key on: it's DC - only after the engine starts: it's AC |
RIP
Posts: 8291 Location: Latina (Italy) |
I thought that AC corresponded to Alternating Current and DC a Direct Current ... I believe that all the electrical system of the scooters (except the older ones) is Direct Current, if that's what you mean ...
Smaller scooters with small batteries often have a specific winding (a phase, so to speak) from the stator that goes directly to the headlight, bypassing the regulator/rectifier. That output is AC, which is fine with incandescent bulbs but can be problematic with LED replacements.
This is so the relatively high drain of the headlight (35 watts, or more) doesn't reduce the cranking power of the little battery.
Positive
I was installing a signal dynamics headlight module. Sweet simple design. But when done I got nothing. They said the module does not work on AC. Never occurred to me my Vespa was AC. Bummer.
And now, can I return it? We shall see. |
RIP
Juan_ORhea wrote: Smaller scooters with small batteries often have a specific winding (a phase, so to speak) from the stator that goes directly to the headlight, bypassing the regulator/rectifier. That output is AC, which is fine with incandescent bulbs but can be problematic with LED replacements. This is so the relatively high drain of the headlight (35 watts, or more) doesn't reduce the cranking power of the little battery. Thanks for the clarification. PS: on Yamaha scooters (at least on X Max and Tricity) when you press the starter the headlights go out momentarily. |
Signal Dynamics has 100% money back guarantee. So back it goes. Too bad because theirs was really plug and play. Nice design.
Posts: 11594 Location: Hermit Kingdom |
Juan_ORhea wrote: If the headlight comes on: - when you turn the ignition key on: it's DC - only after the engine starts: it's AC |
Posts: 46053 Location: Pleasant Hill, CA |
Pretty sure it's true of all 50cc scooters like the OP's.
Are there larger modern scooters with AC headlights? All the 150s and larger I've messed with are DC. |
