Vespa Elettrica
Vespa Elettrica
Guys i got a question i have recently bought an Vespa Elettrica.
My question is is there any chance to upgrade the speed? It goed around 25km an hour. Too speed is around 28 but i want to let it go around 40/45. Someone has any idea how i can do that?
Vespa Elettrica, GTS 300 HPE
Hi. If your Elettrica tops out at 25km/hour, it needs repair.
There are two Elettrica models. One has a max speed of around 48km/h, and the other around 70km/h.
Either model can be set to Eco mode, where the top speed is significantly lower. I would suggest carefully reading the manual to confirm you're operating it in Power mode (not Eco mode), and if you are, consulting your dealer to diagnose and repair the problem.
@seamus26 avatar
@seamus26 avatar
I talked to our local dealer about just this. The thing about the two models is ... they are the same. Top speed set at the factory, and even the dealers don't have the ability to change it. The difference is in the programming/software/firmware.
He also told me that the 70km/hr model eats up battery power much faster than specs in the real world.
But yeah. Contact your dealer.
Vespa Elettrica 70km
Not true , your dealership is incorrect seamus26 my Elettrica 70 does exactly what the specs says except it goes 1mph faster at 44mph rather than the 43mph that is published .
My 70km/h Elettrica is right on spec with battery consumption and capacity (range). My top speed seems to be about 1mph above the max specified. I have about 1,600 miles on it.
More to the point, no model of Elettrica should have the speed limitation OP is encountering, unless he's put it into Eco mode.
⬆️    About 3 years elapsed    ⬇️
Elettrica 45
Elettrica 45
Great mind your dealer. If you want to go faster you have to replace a part in the final drive. 45-52or 70 ring is available but cost is high.
Elettrica 45
Elettrica 45
I've just received the parts. The cost was 220€
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
When I looked at this a couple of years ago, you could push a 45 Elettrica a bit, but you couldn't push it to the same speed as the 70. From memory, the aftermarket final drive gave you about a 9km/h / 6mph boost.
Can you now push a 45 even further, and also push the 70?
My speedo was always 3mph above at all speeds, so 28mph showed as 31mph on the dash. Power would be cut at the indicated 31mph, but it was possible to go quicker if you were going downhill - so it was never limited by gears, only the motor was programmed to cut out at a certain speed.
⬆️    About 9 months elapsed    ⬇️
elettrica
elettrica
can U send me link please
@jicao avatar
Vespa Primavera Elettrica 70 Tech
@jicao avatar
I am curious too
[ Time: 0.0144s ][ Queries: 3 (0.0037s) ][ live ][ 343 ][ ThingOne ]
