I'm looking for a maintenance manual or factory workshop type for my new Vespa GTS. ANY SUGGESTIONS
Posts: 7695 Location: Madison, Wisconsin |
You'll get 90% or more of the information you need from a prior year manual.
I used to buy Hanes manuals for my cars, then stopped about 10 years ago or so. Brakes are brakes, oil changes are all about the same, etc. Just gain experience, then go by the manufacturer's time intervals for things. YMMV. |
Meade wrote: I agree but, isn't the hp engine different enough to need some new info? |
Posts: 45704 Location: Pleasant Hill, CA |
Sheesh. Is there a problem with https://manuals.wotmeworry.org.uk/Vespa/GTS%20300i%20HPE/
I've got the owner's manual. We're talkin about a workshop manual for the HPE.
Edit... now I see the workshop manuals in the parent directory. Thanks for that. Only problem is it is from 2008. Still fun and interesting to read. |
Posts: 3766 Location: East Anglia, UK |
Yeah, the factory workshop manual is what I always use if doing a complete engine rebuild on any engine I'm unfamiliar with. You get the exact engine tolerances that you need to work to and all the other specs straight from the horses mouth, rather than from a third party. Although Haynes manuals are pretty good and over the years I've rarely been able to fault them. If you wait another year or so the HPE Haynes manual will come out. It takes a little time to produce them when there is a model change.
I've seen inside the HPE engine and it is substantially different in several areas. Although the basic design is still very close to the previous motor, there has been substantial evolution. It's an excellent engine! |
RIP
Posts: 8291 Location: Latina (Italy) |
GTS 300ABS, Buddy Kick 125
Posts: 13550 Location: Oregon City, OR |
Max6200 wrote: Does the 2018 HPE have hydraulic brakes? You won't find that in the Hayne's manual. |
Dooglas wrote: Hasn't the GTS had front and rear hydraulic discs since the introduction of that model in 2006? (both my '08 and my '15 do) |
You can buy a manual download from AF1 Racing; just $8.99.
https://www.af1racing.com/OEM-Vespa-Workshop-Manual-GTS-300-HPE
Positive
I found these online are they not for the Vespa GTS SuperTech 300 HPE?
/www.vespaforum.com/manuals/Vespa/GTS300%20Super or is the above manual from AF12 better suited? |
iSilentP wrote: I found these online are they not for the Vespa GTS SuperTech 300 HPE? /www.vespaforum.com/manuals/Vespa/GTS300%20Super or is the above manual from AF12 better suited? https://manuals.wotmeworry.org.uk/Vespa/GTS300%20Super/ Sorry, this is the best I can do for the HPE, until some kind soul provides me with further info: https://manuals.wotmeworry.org.uk/Vespa/GTS%20300i%20HPE/ |
Max6200 wrote: Does the 2018 HPE have abs/hydraulic brakes? You won't find that in the Hayne's manual. |
cadbury64 wrote: You can buy a manual download from AF1 Racing; just $8.99. https://www.af1racing.com/OEM-Vespa-Workshop-Manual-GTS-300-HPE |
Since we're on the subject of manuals, will this work for a '12 GTS 300 Super and a '13 GTS 300ie?
https://www.vespaforum.com/manuals/Vespa/GTS300%20Super/ |
Guzzi Gal wrote: Since we're on the subject of manuals, will this work for a '12 GTS 300 Super and a '13 GTS 300ie? https://www.vespaforum.com/manuals/Vespa/GTS300%20Super/ |
