1968 VBB150
1968 VBB150
Ok, update time!
Did some minor frame straightening (pics below) and its off to the welder to fix the leg shield crack and tail issues. After that on to the body work and finally paint a nice shiny two stage red. I contemplated original, but really really want a red one.
On the hunt for VBA cowls, wallet open.
1968 VBB150
1968 VBB150
Also, I can open the bottom, drill the side, or drill small and use a slide hammer to repair the tunnel dings/creasel- I would like some opinions/feedeback on which to do. I am leaning slide hammer since it will make the least damage and I can back it with washers to get a clean flat finish.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Ahah! I thought of a trick you could try, using a slide hammer and NO drilling. I was taught this long ago, by an old school body man; my teacher when I took welding & bodywork class long ago...
Dont drill holes for the slide hammer. Instead, tack weld on a few washers to the frame. Then replace the 'screw-grabber part" on the end of your slidehammer with a Hook-type-thing. Then hook on to your welded-washers, and pull away. When done, snap off the washers and sand it smooth. No drilling/filling required. I've done this way, and it works! Worth a shot!
@chandlerman avatar
Innovator
104 Days Since Last Explosion
Innovator
@chandlerman avatar
For a suitable number of dollars, You can now buy a tool that will spot weld a rivet-looking thing onto the frame like a reverse nailgun for doing exactly what GL was taught.
GL's method is nominally more work, but a heck of a lot cheaper, I'm sure.
1968 VBB150
1968 VBB150
Hmm. $359 for the kit... Hmmm...
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
If you have a mig, you can weld nails as studs, weld a slide hammer to vice grips. Less than $100 depending on slide hammer and vice grips.
I've purchased stuff like this that I only really care about working once. I have a grinder, I needed to use for maybe 20 minutes but was 2.5 hours from home. Cheap and quick and if you weren't done you could exchange it for another.
https://www.harborfreight.com/stud-welder-dent-repair-kit-61433.html
1968 VBB150
1968 VBB150
$109 even better- gonna pull the trigger on this one
@garncarz avatar
@garncarz avatar
So, what do you got under the hood in that cozy coupe? Looks like the front forks are bent, but sweet ride otherwise.
1968 VBB150
1968 VBB150
Its got like two tiny legpower, but can be upgraded with the "Cousin shover" option, which gets like FOUR. Brakes are shot though, runs into everything.
@garncarz avatar
@garncarz avatar
Laughing emoticon
parallelogramerist
parallelogramerist
I bought a Uni Spotter brand back in 1996. It was definitely a game changer for me.
[ Time: 0.0144s ][ Queries: 4 (0.0033s) ][ live ][ 342 ][ ThingOne ]
